Hi all,
I create node. And it has validate function for its field.
Validation has using value from 'TypedInput Select box'. They names 'node-input-action' and 'node-input-datetimeMode'. But the problem is from 'node-input-datetimeMode'.
Please see below
datetimeInitialDate: {
value: "",
validate: function (v) {
if ($("#node-input-action").typedInput('value') === ACTION_DATETIMEPICKER) {
if ($("#node-input-datetimeMode").typedInput('value') === DATETIME_MODE_DATETIME || $("#node-input-datetimeMode").typedInput('value') === DATETIME_MODE_DATE) {
if (!v.match(/^\s*$/)) {
const result = isValidDate(v);
return result;
} else {
return true;
} else {
return true;
} else {
return true;
After I run flow on browser, the client error is occured.
Validation error: node-line-bot-quick-reply-item 3f71c1a2ce19ff2a property: datetimeInitialDate value: Error: cannot call methods on typedInput prior to initialization; attempted to call method 'value'
at Function.error (vendor.js?v=2.2.2:2:2589)
at HTMLInputElement.<anonymous> (vendor.js?v=2.2.2:10:5615)
at Function.each (vendor.js?v=2.2.2:2:2976)
at s.fn.init.each (vendor.js?v=2.2.2:2:1454)
at s.fn.init.t.fn.<computed> [as typedInput] (vendor.js?v=2.2.2:10:5357)
at Object.validate (<anonymous>:316:59)
at a (red.min.js?v=2.2.2:18:373999)
at i (red.min.js?v=2.2.2:18:374649)
at v (red.min.js?v=2.2.2:18:374357)
at HTMLInputElement.<anonymous> (red.min.js?v=2.2.2:18:375995)
So how does to fix node validati error, when it get value from TyponedInput Select box? ![]()
Moreover, I guest when I remove only code for reading 'node-input-datetimeMode' value, reading 'node-input-action' value is not error. ![]()
