How get and route a single pair of key/value from an object?
Hi. I'm moving my first steps in node-red, and I'm facing a lot of problems since the template flow that I need to use for my needs contains a lot of stuff that I still don't understand.
My first need is to create some objects that contains each one the values of the object "dps" that I have retrieved within a payload:
{"devId":"228780332cf432062e35","dps":{"1":false,"2":15,"3":24,"7":false,"10":"0","11":0,"101":"0","102":false}}
I've checked the path of the keys, for example payload.dps["1"] but how could I obtain a pair of key/value to send via mqtt?
Thank you
I am sorry, I don't understand exactly what you need to send to MQTT. Can you give us an example of exactly what you want to send?
You can create an object with key/value like this in a function node...
msg.payload = {
  key: "value"
so if you want the value of dps in a key/val you would...
msg.payload = {
  dps: msg.payload.dps["1"]
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
Of course @Colin: I need to control locally a tuya appliance that I can't integrate in home Assistant with the LocalTuya custom component.
With the node-red-contrib-tuya-local node I can control that appliance, and my main idea is to use MQTT as a bridge between Node-Red and HA, and to create a climate device based on MQTT.
The node's payload {"devId":"228780332cf432062e35","dps":{"1":false,"2":15,"3":24,"7":false,"10":"0","11":0,"101":"0","102":false}} showed me the dps keys/values that I should send to MQTT, for example the payload.dps["7"] routed to something like "/tuya/bimar_local/swing/" (that is a nice example, since I can't control that function with HA), and so on.
Use a change node
NOTE: topics should never start and end with a / slash.
Thank you, that worked like a charm!
Looking around I've found the way to convert also the value of my key:
msg.payload = {
  power: msg.payload.dps["1"] ?  "on" : "off"
Is that language JavaScript?
Sorry I've replied before reading your post.
Is it possible to set not only the key 7 as msg.payload but also convert its value from boolean to "on" and "off"?
I'm trying to obtain that with the expression of my previous reply but without success. I imagine that it happens because I should write in JSonata?
Just use a function node & set the payload and topic as desired...
msg.payload = {
msg.topic ="tuya/bimar_local/swing";
Ps, yes, it is JavaScript.
