How node sizes are calculated?
Hi everyone,
when I use a node and I name it the size changes depending on the length of the name, how is this size calculated?
Thank you in advance for your reply
Hi @riri
As i am certain you are aware, it is calculated based on the label length and the grid size setting.
Do you need to know the actual calculations / is there a technical reason?
You are free to go on a voyage of discovery and browse the source code to find the answer :smiley:
The width makes some allowance for the width of the characters.
But if you change the font size it makes no difference
Depends on how you changed the font. Assuming you did this in the browser directly (and not modified a CSS and refreshed the page)? I ask because I am fairly certain the calcs do a getComputedTextLength (or getBBox or similar) at draw time (in other words, layout does not reflow because a CSS value changed post drawing)
Yes, that's right.
thank you for the answer I look for the size of the default cells because I have to create an algorithm that displays a list of nodes in the form of graph and I would like to avoid that some blocks eat part of the other blocks . I hope someone knew the name of the function that handles this but I will go explore the bowels of node-red
