How do you change the size of each individual node
after 6 month's, I'm still learning node-red. I'm stuck on resizing various nodes. I imported a sample PID flow to compare it to what I've been working on. However, 90% of the nodes have been reduced to small squares similar to the attached.
How do I get all the nodes back to their original size in the palette; without having to to drag each node in then transfer the code to the new node?
Thanks.
Hi Keefer,
This is controlled by a setting on each node:
Untitled 1
I don't think there is any easy way to avoid changing them one by one.
Luckily there are multiple ways.
  • Select the nodes, right-click (or cmd+shift+p like vscode) > show action list > search "label" > show/hide label
  • Or via shortcuts, which can be setup via the hamburger menu > manage palette > keyboard tab
WOW! I wanted to ask this question since very long, some one did and i found this answer. Thanks for the OP.
thanks guys, works like achamp
