How to get "Edit node" window smaller
Hello!
How do I get the "Edit node" window smaller? I have tried to make my right column smaller, but I can't edit the width of the node extension. I can't see all of the window. It's only like this in the node-red-contrib-bool-gate addon. All other extensions are okay.
Here is my problem: Image of problem
You will need to raise this with the Author, but sadly has no GitHub in any literature
Hi. Welcome to the forum.
Firstly, please don't publish links to images from those god awful , popup creating, advert showing, notification laden share sites. Just paste the image directly into the reply.
As for your problem, you will need to contact the node author.
If you search the flows library (link above) for that node, you will find a link to their repository - where you can raise an issue.
