How to access context in a change node using the J: method
Sorry, I know I've asked before but it is possible.
I want to do some maths on a context but can't remember how to do that trick.
I seem to remember in the change node you set it something like:
J: flow.get("something") * 2
and that will give me flow.get("something") value multiplied by 2.
But when I'm doing it now, I get undefined.
example / solution.
J: $globalContext("SCAN_TIME")
(Just incase anyone else is interested.)
Unless you need to do it dynamically, you can just do,
set msg. var
to global. SCAN_TIME
Only use JSONata if needed as it has overheads.
Just for others info.
Thanks.
I'm not exactly sure about if that is or not FIXED.... I think most of the time it is, but I need it to be changed in this case dynamically if the global value is changed.....
Then I add a fudge factor to it.
So really it is:
J: $globalContext("SCAN_TIME") * 1.5 So there is wiggle room if the timing goes off.
But thanks for the reply.
Oh, and I did it this way to NOT use a function node.
(Though most of the time I shall say I am guilty of doing that. But to keep the memory working I thought it would be nice to do it in a change node instead.)
(Also to explain why I am doing it this way)
