What is the trick to access global variables form within a change node?
I was wanting to do maths things to it and so to simply set/get it I would then need a function node, but someone posted me how to do it.
I seem to remember it was in the J: part of the change node.
But I have tried searching the flows and couldn't find it so I tried searching for my question and (alas) also couldn't find it.
Sorry folks.
In a JSONata Expression you can do $globalContext("FOO")
Thanks.
I don't think that was how I was shown.
It looked something like:
J: for the type of entry in the line. Then something like:
{("global.foo")} * 3
But as I am not sure for what it is I am searching, it makes it difficult to search the flows.
Will a search search in a change node for stuff typed?
Found it!
This is how I was shown.
[{"id":"843af767.23caa8","type":"switch","z":"9b7e7466.a4b698","d":true,"name":"EXTREME HEAT 1","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"$globalContext(\"Shutdown_temperature\")-10","vt":"jsonata"}],"checkall":"true","repair":false,"outputs":1,"x":1865,"y":340,"wires":[["5da5a554.5275ac"]]}]
Ok, the node is disabled. But that is how it was shown to me.
Sorry for not remembering.
Actually you probably are/were right. I just didn't see it as it would be shown in the node.
Thanks again though.
