How to add modbus tcp library in node-red
I am trying to get data from plc that support modbus TCP IP.
how to add modbus tcp library in node-red to read data from PLC.
kindly help for the same.
Go to flows.nodered.org find the node you want to install.
Most nodes include in their readme the instructions on how to install via the command line.
Alternatively you can install via the manage palette option in the menu of Node-RED
thank you
its done
i got the data on msg.payload from plc.
