Modbus tcp not installed
Hi All!
Im newbe in node-red, I installed it on PI 4 B(2GB), and when I do install,- npm install node-red-contrib-modbus-tcp-ip
I have got the folling install flow
npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
  • node-red-contrib-modbus-tcp-ip@1.1.5
    updated 1 package and audited 12 packages in 2.33s
    found 0 vulnerabilities
    After that in node red i cant find appropriates nodes
    The same situations with
    npm install node-red-contrib-modbustcp
  • node-red-contrib-modbustcp@1.2.3
    updated 1 package and audited 12 packages in 2.097s
So I need help!
Seems like you called npm install from the wrong directory, the node modules got installed directly into your user directory.
You need to change into your Node-RED workspace directory first, usually ~/.node-red and call npm install from there.
Or probably better to use the install method built into node red. Select Manage Palette in the menu drop-down.
Thank you very much, Now Ive got modbus-tcp nodes!!!!
