I’m working with multiple custom Node-RED modules, and I want to execute and view the test case results for all my custom modules while generating a consolidated code coverage report in a single execution.
Folder Structure and Context
Here is an example of my folder structure for one of the custom modules:
Below attached the package.json for reference
"name": "node-red-contrib-create-jwt-token",
"version": "1.0.0",
"description": "",
"main": "create-jwt-token.js",
"keywords": [
"node-red"
"node-red": {
"nodes": {
"create-jwt-token": "create-jwt-token.js"
"nyc": {
"reporter": ["text", "html"],
"report-dir": "./coverage"
"scripts": {
"test": "nyc mocha test/create-jwt-token_spec.js"
"author": "",
"license": "ISC",
"devDependencies": {
"chai": "^5.1.2",
"mocha": "^11.0.1",
"node-red": "^4.0.7",
"node-red-node-test-helper": "^0.3.4",
"sinon": "^19.0.2",
"sinon-chai": "^4.0.0"
Goal
I want to:
- Run tests for all custom modules at once.
- Generate a unified code coverage report for all these modules.
- Export or view the test results for each custom module in one go.
Challenges
- Currently, I can run tests and view coverage for individual modules using nyc mocha, but I’m unsure how to configure this for multiple custom modules collectively in a way that provides a combined coverage report.
Questions
- What’s the best approach to aggregate tests and generate a combined coverage report for multiple Node-RED custom modules?
- Are there specific tools or configurations in nyc or other test frameworks that can facilitate this?
- Any examples or recommendations for managing consolidated test execution and reporting in a Node-RED custom module environment?
- Looking forward to your insights!
Thank you in advance for your guidance.
