Thanks for the quick answer.
Here is the structure:
"id": "d0b817e64cb5e8f3",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": "",
"env": []
"id": "5a1a25108a44a4b7",
"type": "ina-sensor",
"z": "d0b817e64cb5e8f3",
"handle": "68a7603e9b0ab180",
"x": 270,
"y": 240,
"6bdf32801ece1206"
"id": "003214632c94b6b5",
"type": "mqtt in",
"topic": "ina_219_1",
"qos": "2",
"datatype": "auto-detect",
"broker": "4d29b73341f90358",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 100,
"y": 240,
"5a1a25108a44a4b7"
"id": "ae5ce491679590df",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "3",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 110,
"y": 300,
"8fe81bc608d61bec"
"id": "8fe81bc608d61bec",
"type": "ads1x15_i2c",
"property": "payload",
"name": "ADS1115",
"i2c_device_number": 1,
"chip": "0x01",
"i2c_address": "0x48",
"inputsForChannel": "singleEnded",
"singleEndedChannel0": true,
"singleEndedChannel1": false,
"singleEndedChannel2": false,
"singleEndedChannel3": false,
"differentialChannel0_1": true,
"differentialChannel0_3": false,
"differentialChannel1_3": false,
"differentialChannel2_3": false,
"samplesPerSecond0": "920",
"samplesPerSecond1": "128",
"progGainAmp": "6144",
"x": 260,
"y": 300,
"d3269ae4faf888f3"
"id": "d3269ae4faf888f3",
"type": "change",
"name": "extract_value_from_Channel_A0",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload[\"/dev/i2c-1\"].a1115[\"0x4ds8\"].singleEnded.channel_1.Volts",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 480,
"y": 300,
"d33f98b9d8ab1426"
"id": "d33f98b9d8ab1426",
"type": "voltage_undivider",
"name": "Voltagedivider",
"Voltage_Input": "V-Volts",
"Resistor_1": "2200",
"Resistor_1Types": "Ω-Ohm",
"Resistor_2": "200",
"Resistor_2Types": "Ω-Ohm",
"Voltage_Output": "V-Volts",
"Round_Output": "Thousandths",
"x": 740,
"y": 300,
"id": "6bdf32801ece1206",
"type": "smooth",
"action": "mean",
"count": "3",
"round": "3",
"mult": "single",
"reduce": false,
"x": 720,
"y": 240,
"id": "68a7603e9b0ab180",
"type": "ina-sensor-manager",
"address": "0x40",
"delay": "250",
"ohms": "0.01",
"customResistor": false
"id": "4d29b73341f90358",
"type": "mqtt-broker",
"name": "Mqtt INPUT",
"broker": "127.0.0.1",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"autoUnsubscribe": true,
"birthTopic": "",
"birthQos": "0",
"birthRetain": "false",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closeRetain": "false",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willRetain": "false",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
