How to change node Pallette text to bold
How can I change the node pallette text to bold?
Welcome to the forum what do you mean by node palette text can you share a screenshot of the element you want to make bold
Hi
The text in the coloured boxes I would like in BOLD as I cannot read the text in some of the darker coloured boxes.
Thank you
I was able to change the parameters directly in the development, however i am not aware where is the CSS file being fed from.
You can specify a CSS file for the editor in settings.js.
So for example on a Raspberry Pi I have /home/pi/.node-red/editor.css containing
.red-ui-palette-label {
        font-weight: bold;
In settings.js, immediately below the line editorTheme: { add this, using the full pathname of your CSS file
 page: {
          css: "/home/pi/.node-red/editor.css"
Now restart Node-red.
OK Thank you very much.
Hi
Yes that is exaxtly what I want. Thank you
But I am totally new to Node RED and I am not sure what the CSS file is.
I am using Node Red that is attached to Victron.
Victron supply a range of equipment for the Off grid / Solar industry
https://www.victronenergy.net.au/
Would I find the CSS file somewhere in the Victrron system?
https://communityarchive.victronenergy.com/questions/155949/node-red-config-files.html
OK Thank you
