Hi Guys,
I was playing arround with the settings file feature called Editor Theme.
I was able to do everything, except the CSS manipulation
i get stuck with not knowing where to find an example
does anyone have a Sample file of this feature which could be shared?
editorTheme: {
page: {
title: "Node-RED",
favicon: "/absolute/path/to/theme/icon", //can use '__dirname + "\\img\\favicon.png" (\\ on Windows)'
**css: "/absolute/path/to/custom/css/file",**
scripts: "/absolute/path/to/custom/js/file" // As of 0.17
header: {
title: "Node-RED",
image: "/absolute/path/to/header/image", // or null to remove image
url: "http://nodered.org" // optional url to make the header text/image a link to this url
deployButton: {
type:"simple",
label:"Save",
icon: "/absolute/path/to/deploy/button/image" // or null to remove image
menu: { // Hide unwanted menu items by id. see editor/js/main.js:loadEditor for complete list
"menu-item-import-library": false,
"menu-item-export-library": false,
"menu-item-keyboard-shortcuts": false,
"menu-item-help": {
label: "Alternative Help Link Text",
url: "http://example.com"
userMenu: false, // Hide the user-menu even if adminAuth is enabled
login: {
image: "/absolute/path/to/login/page/big/image" // a 256x256 image
logout: {
redirect: "http://example.com" // As of 0.17
palette: {
editable: true, // Enable/disable the Palette Manager
catalogues: [ // Alternative palette manager catalogues
'https://catalogue.nodered.org/catalogue.json'
theme: [ // Override node colours - rules test against category/type by RegExp.
{ category: ".*", type: ".*", color: "#f0f" }
projects: {
enabled: false // Enable the projects feature
