Hi. maybe this has been answered before.
I am using different nodes (ds18b20 and rpi-dht22) to get data from sensors.
these come with eg. 21,22xxxx values - and when pasting the payload to a MSSQL-Plus node to save them to a database I only get the 21 so I guess that I will have to change the payload from 21,22xxxx yo 21.22xxxx - but how do I do that
You could try:
I'll look into that . thanks
(I think) There is/are tricks. If you want ALL of them converted you have to do something else....
Sorry, it's been too long for me needing/using it.
Sorry ... my mistake ...
When I created the column in the SQL db. I made the datatype an INT - and not a decimal.
now it works
thanks
Mark the tread as solved at the bottom of the post that solves the question.
