SNMP msg.payload changed between versions
I've recently upgraded from Node-RED v3.0.2 with the node-red-node-snmp node v0.0.25, to Node-RED v3.1.3 with node-red-node-snmp node v2.0.0.
I'm noticing a difference in how the output from the SNMP node is displayed in the never version combination, which is breaking some further processing.
Historically, I used to be able to get the value "on" from payload[0].value in:
However in the latest version, I'm getting the hexadecimal. I can click on 'raw' which changes it to string and shows correctly, but unlike the previous versions, that isn't actually what's being passed on in payload[0].value.
Is there any way to either specify that I want the text or convert the payload?
Once I've tidied it up, I'd like to see:
{"device":"UPS Eco Mode","reading":"on"}
but instead I'm seeing:
{"device":"UPS Eco Mode","reading":[111,110]}
Many thanks!!!
Use .toString() on the value
Thank you @Steve-Mcl - I didn't see the other post :slight_smile:
