How to change the default color of ui_gauge
Hello everyone, I would like to know if it is possible for me to change the selected color in the image through a ui-control, or some other external css file
That way I can enter the max and min values dynamically, since it's not possible to change the internal settings, is it possible to change it through "ui_control"?
var total = msg.payload.Total
var disponivel = msg.payload.Disponivel
var indisponivel = msg.payload.Indisponivel
msg = {ui_control:{min: 0, max:total}}, msg.payload = disponivel;
Many many options can be changed via msg.ui_control
Flow:
[{"id":"8a9931c63ddf715b","type":"inject","z":"afcfe6f7a144f0b4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":230,"y":620,"wires":[["468db23d521c4844"]]},{"id":"468db23d521c4844","type":"random","z":"afcfe6f7a144f0b4","name":"","low":1,"high":10,"inte":"true","property":"payload","x":400,"y":620,"wires":[["de06e2704d7ddfe6"]]},{"id":"de06e2704d7ddfe6","type":"ui_gauge","z":"afcfe6f7a144f0b4","name":"","group":"d129285e4b08a665","order":2,"width":"3","height":"3","gtype":"donut","title":"gauge","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":570,"y":660,"wires":[]},{"id":"9ab1252e4c2a76e6","type":"inject","z":"afcfe6f7a144f0b4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":660,"wires":[["9d83cf7302235638"]]},{"id":"9d83cf7302235638","type":"change","z":"afcfe6f7a144f0b4","name":"gauge color","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"options\":{\"gaugeColor\":\"#ff00ff\"}}","tot":"json"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":660,"wires":[["de06e2704d7ddfe6"]]},{"id":"d129285e4b08a665","type":"ui_group","name":"Select Station","tab":"85850867b381145e","order":1,"disp":true,"width":"6","collapse":false},{"id":"85850867b381145e","type":"ui_tab","name":"Trains","icon":"dashboard","disabled":false,"hidden":false}]
