How to check for gauge clicks
Hello ereryone!
I have a project with a list of gauges and I need to detect the individual click of each of them. I don't know the best way to do this, nor do I know if there is a library that will help me with this situation.
This is my individual gauge configuration:
Can anyone help me?
Thanks in advance!
As you see, the gauge node has no output. So there is no way to get any kind of feedback when you do click on the gauge.
Thanks for the reply!
Does that mean there is no way to do click management in javascript being like that?
So my only solution in this case is to add a button to each of my gauges?
There is of course way to add click handler to any element on your dashboard but it really depends on too many things so I can't give fully working solution or any better advise.
But if you can figure out the technique from this example - you may be get closer to your goal.
[{"id":"60121bbf4de72aee","type":"ui_gauge","z":"9141c3fbcc7d9e2b","name":"","group":"f6124e036e2d2ffb","order":14,"width":"2","height":"2","gtype":"gage","title":"gauge 1","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"gauge-clickable","x":380,"y":1400,"wires":[]},{"id":"dfbf8667ded5e478","type":"ui_gauge","z":"9141c3fbcc7d9e2b","name":"","group":"f6124e036e2d2ffb","order":14,"width":"2","height":"2","gtype":"gage","title":"gauge 2","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"gauge-clickable","x":380,"y":1440,"wires":[]},{"id":"fd313c3c6dde471f","type":"ui_template","z":"9141c3fbcc7d9e2b","group":"f6124e036e2d2ffb","name":"gauge's clickhandler","order":16,"width":0,"height":0,"format":"<script>\n    (function(scope) {\n      setTimeout(init,500)\n      function init(){\n        let gauges = document.querySelectorAll(\".gauge-clickable\")       \n        Array.from(gauges, (gauge) => {         \n            gauge.addEventListener(\"click\", function(e) {          \n              scope.send({payload:$(gauge).children('p').first().text()})\n            })\n         })\n      }\n  \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":420,"y":1540,"wires":[["a99fe1fa59345834"]]},{"id":"a99fe1fa59345834","type":"debug","z":"9141c3fbcc7d9e2b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":630,"y":1540,"wires":[]},{"id":"ef025df640d76f1d","type":"ui_gauge","z":"9141c3fbcc7d9e2b","name":"","group":"f6124e036e2d2ffb","order":14,"width":"2","height":"2","gtype":"gage","title":"gauge 5","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","className":"gauge-clickable","x":380,"y":1480,"wires":[]},{"id":"f6124e036e2d2ffb","type":"ui_group","name":"Default","tab":"34ab7d39f3e308fc","order":1,"disp":true,"width":"5","collapse":false,"className":""},{"id":"34ab7d39f3e308fc","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Ohh nice example. I think I can handle it from here now.
Thanks for the help!
