I am working on a little auth middleware experiment and I want to enforce some settings before enabling the middleware, such as https and cred encryption.
When not using projects, I can simply check if RED.settings.credentialSecret === false and reasonably assume that the creds are not encrypted due to the explicit setting.
When using projects, I cannot seem to find an api that can give me the info. Of course, I can check for the value manually to see if it is === false wrapped in a try/catch block in case the files don't exist:
const { projects, activeProject } = require(`${RED.settings.userDir}/.config.projects.json`);
const { credentialSecret } = projects[activeProject];
Well, I found a different way using the runtime api. Of course, I would prefer if the project data was already available to the node, but it works just fine.
module.paths.push(process.env.NODE_RED_HOME);
const runtime = require('node_modules/@node-red/runtime');
runtime.projects.getActiveProject(process.env.USER)
.then(project => {
console.log(data.credentialSecret === false);
Requiring the node_modules/@node-red is loosely based on how ralphwetzel does it in node-red-mcu-plugin/mcu_plugin.js at main · ralphwetzel/node-red-mcu-plugin · GitHub, with the small change of pushing the path for require to find the global libs and then not need another dependency such as resolve-package-path.
