How to collect information from multiple sources and have them seperately analyzed
My goal is to collect health information of different servers and have them put into MQTT-topics.
As I don't like to copy the flows for each server (I'm collecting the exact same data, but from multiple sources), I come from a list of servers and like to push them into seperate MQTT-topics, which I then can monitor and take necessary action if e.g. one server runs into problems.
So, basically I do the following:
global.set("hostname", "openhabmain");
global.set("hostip", "192.168.xx.xx");
global.set("metricsurl", "http://192.168.xx.xx:8080/rest/metrics/prometheus")
msg.url = global.get("metricsurl");
msg.payload = global.get("hostip");
node.send(msg);
global.set("hostname", "openhabutilities");
node.send(msg);
later on, if a got my response I send them to different mqtt-topics:
    msg1.payload = Object.assign(msg.payload[key]);
    msg1.topic = "openHAB/master/snmp/" + global.get("hostname") + "/" + key;
    node.send(msg1)
But as soon as I inject the flow, the "global variable" gets overwritten and I basically get only one set of information. So what is the best practise here, to have flow specific variables?
if it helps, here a screenshot and the flow:
grafik
Flow
        "id": "eb920791.e124e8",
        "type": "inject",
        "z": "84ed84b2.83431",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "300",
        "crontab": "",
        "once": false,
        "onceDelay": "",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 230,
        "y": 600,
                "de4a1af6.4ae9b"
        "id": "71173d2a.39309c",
        "type": "http request",
        "name": "getOpenhabMetrics",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "body",
        "url": "",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 370,
        "y": 720,
                "344c1065.04ad48"
        "id": "344c1065.04ad48",
        "type": "function",
        "name": "Metrics2JSON",
        "func": "var lines = msg.payload.split(\"\\n\");\n\nvar json = \"{\";\nvar json_object = {};\n\nfor(var i = 0;i < lines.length;i++){\n    // ist es eine Kommentar-Zeile?\n    if (!lines[i].startsWith(\"#\")) {\n        // ist es eine kurze \"Leerzeile\"?\n        lines[i] = lines[i];\n        if (lines[i].length > 5) {\n            var data_tmp1 = lines[i].split(\"{\");\n            var data_name = data_tmp1[0]; // Datenbezeichnung \n            var data_tmp2 = data_tmp1[1].split(\"}\");\n            var data_value = data_tmp2[1].replace(\" \", \"\"); // Datenwert\n            var data_meta = data_tmp2[0]; // Daten-Meta\n            \n            data_meta = data_meta.replace(/=/g, '\": ');\n            data_meta = data_meta.replace(/,/g, ',\"');\n            if(data_name in json_object == false){\n                json_object[data_name] = {};\n            }\n            \n            var data_injson = true;\n            var data_distinquisher = \"\";\n            // json zusammensetzen\n            switch(true){\n                case data_name == \"jvm_threads_daemon_threads\":\n                    data_distinquisher = \"\";\n                    break;\n                case data_name == \"jvm_buffer_count_buffers\":\n                    data_distinquisher = \"id\";\n                    break;\n                case data_name == \"jvm_threads_states_threads\":\n                    data_distinquisher = \",state\";\n                    break;\n                case data_name == \"jvm_memory_max_bytes\":\n                    data_distinquisher = \"id\";\n                    break;\n                case data_name == \"executor_queued_tasks\":\n                    data_distinquisher = \"pool\";\n                    break;\n                case data_name == \"executor_pool_core_threads\":\n                    data_distinquisher = \"pool\";\n                    break;\n                case data_name == \"event_count_total\":\n                    data_injson = false;\n                    break;\n                case data_name == \"executor_pool_core_threads\":\n                    data_distinquisher = \"pool\";\n                    break;\n                case data_name == \"jvm_buffer_total_capacity_bytes\":\n                    data_distinquisher = \"id\";\n                    break;\n                case data_name == \"jvm_memory_used_bytes\":\n                    data_distinquisher = \"id\";\n                    break;\n                case data_name == \"openhab_rule_runs_total\":\n                    data_injson = false;\n                    break;\n                case data_name == \"executor_pool_size_threads\":\n                    data_injson = false;\n                    break;\n                case data_name == \"jvm_buffer_memory_used_bytes\":\n                    data_distinquisher = \"id\";\n                    break;\n                case data_name == \"executor_active_threads\":\n                    data_injson = false;\n                    break;\n                case data_name == \"jvm_memory_committed_bytes\":\n                    data_injson = false;\n                    break;\n                case data_name == \"executor_completed_tasks_total\":\n                    data_injson = false;\n                    break;\n                case data_name == \"openhab_bundle_state\":\n                    data_injson = false;\n                    break;\n                case data_name == \"executor_pool_max_threads\":\n                    data_injson = false;\n                    break;\n                case data_name == \"jvm_gc_pause_seconds_count\":\n                    data_injson = false;\n                    break;\n                case data_name == \"jvm_gc_pause_seconds_sum\":\n                    data_injson = false;\n                    break;\n                case data_name == \"jvm_gc_pause_seconds_max\":\n                    data_injson = false;\n                    break;\n                case data_name == \"openhab_thing_state\":\n                    data_distinquisher = \"thing\";\n                    break;\n                case data_name == \"executor_queue_remaining_tasks\":\n                    data_injson = false;\n                    break;\n                default:\n                    data_distinquisher = \"\";\n            }\n            \n            if (data_injson == true){\n                if (data_distinquisher != \"\") {\n                    var data_att_tmp1 = lines[i].split(data_distinquisher);\n                    var data_att_tmp2 = data_att_tmp1[1].split(',');\n                    data_name_sub = data_att_tmp2[0].replace('=\"', '');\n                    data_name_sub = data_name_sub.replace('\"', '');\n                    // json_object[data_name].push(data_name_sub);\n                    json_object[data_name][data_name_sub] = data_value;\n                }\n                if (data_distinquisher == \"\") {\n                    data_name_sub = \"value\";\n                    // json_object[data_name].push(data_name_sub);\n                    json_object[data_name][data_name_sub] = data_value;\n                }\n\n                json += '\"' + data_name + '\": {';\n                json += '\"' + data_meta;\n                json += 'value\": \"' + data_value + '\"},';\n            }\n        }\n    }\n}\njson += '\"timestamp\": 123}';\n\n/*\nmsg.payload = data_name; // executor_queue_remaining_tasks\nnode.send(msg);\nmsg.payload = data_value; //  2.147483647E9\nnode.send(msg);\nmsg.payload = data_meta; // metric=\"openhab.core.metric.threadpools\",name=\"lsp\",openhab_core_metric=\"true\",pool=\"lsp\",\nnode.send(msg);\n*/\n\nmsg.payload = JSON.stringify(json_object);\nreturn msg;\n\n\n// executor_queue_remaining_tasks{metric=\"openhab.core.metric.threadpools\",name=\"lsp\",openhab_core_metric=\"true\",pool=\"lsp\",} 2.147483647E9\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 320,
        "y": 840,
                "543607f4.df7328",
                "ce6de5b9.c96a7"
        "id": "543607f4.df7328",
        "type": "json",
        "name": "JSON2JSObject",
        "property": "payload",
        "action": "obj",
        "pretty": true,
        "x": 320,
        "y": 940,
                "a65939ae.ad9d88"
        "id": "9aa67c3f.8ef998",
        "type": "mqtt out",
        "topic": "",
        "qos": "1",
        "retain": "true",
        "broker": "4672ca10.309984",
        "x": 730,
        "y": 1060,
        "id": "a65939ae.ad9d88",
        "type": "function",
        "name": "Object2MQTT",
        "func": "for (let key in msg.payload){\n    let msg1 = {payload:{}};\n    // msg1.payload[key] = Object.assign(msg.payload[key],{\"key\":key});\n    msg1.payload = Object.assign(msg.payload[key]);\n    msg1.topic = \"openHAB/master/snmp/\" + global.get(\"hostname\") + \"/\" + key;\n    node.send(msg1)\n}\nreturn;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 520,
        "y": 940,
                "9b49727.034581",
                "462efda4.e53c84"
        "id": "9b49727.034581",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 750,
        "y": 940,
        "id": "ce6de5b9.c96a7",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 550,
        "y": 880,
        "id": "462efda4.e53c84",
        "type": "rbe",
        "name": "only changes",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "x": 590,
        "y": 1060,
                "9aa67c3f.8ef998"
        "id": "de4a1af6.4ae9b",
        "type": "function",
        "name": "openHAB-Metrics",
        "func": "/*\nglobal.set(\"hostname\", \"nodered\");\nglobal.set(\"hostip\", \"192.168.xx.xx\");\n\nmsg.payload = global.get(\"hostip\");\nnode.send(msg);\n*/\n\nglobal.set(\"hostname\", \"openhabmain\");\nglobal.set(\"hostip\", \"192.168.xx.xx\");\nglobal.set(\"metricsurl\", \"http://192.168.xx.xx:8080/rest/metrics/prometheus\")\n\nmsg.url = global.get(\"metricsurl\");\nmsg.payload = global.get(\"hostip\");\nnode.send(msg);\n\nglobal.set(\"hostname\", \"openhabutilities\");\nglobal.set(\"hostip\", \"192.168.xx.xx\");\nglobal.set(\"metricsurl\", \"http://192.168.xx.xx:8080/rest/metrics/prometheus\")\n\nmsg.url = global.get(\"metricsurl\");\nmsg.payload = global.get(\"hostip\");\nnode.send(msg);",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 290,
        "y": 660,
                "71173d2a.39309c"
        "id": "4672ca10.309984",
        "type": "mqtt-broker",
        "name": "Synology",
        "broker": "192.168.xx.xx",
        "port": "1883",
        "clientid": "nodered",
        "usetls": false,
        "compatmode": false,
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "openHAB/master/nodered",
        "birthQos": "2",
        "birthRetain": "true",
        "birthPayload": "ON",
        "closeTopic": "openHAB/master/nodered",
        "closeQos": "2",
        "closeRetain": "true",
        "closePayload": "OFF",
        "willTopic": "openHAB/master/nodered",
        "willQos": "2",
        "willRetain": "true",
        "willPayload": "OFF"
Thanks!
As you have found out, global variables are not the way to go, especially when you want to reuse a flow but with different parameters (i.e. which server to connect to, and which topic to use).
The approach I like to use is to inject an array of objects, each with the parameterized data that is needed inside the main flow. So for your use case, maybe something like this in an inject node:
    "hostname": "openhabmain",
    "hostip": "192.168.xx.xx",
    "metricsurl": "http://192.168.xx.xx:8080/rest/metrics/prometheus"
    "hostname": "openhabutilities",
    "hostip": "192.168.yy.yy",
    "metricsurl": "http://192.168.yy.yy:8080/rest/metrics/prometheus"
Then use a split node wired into your main flow (I like to use link nodes here, but the new link call is ideal for this case). When your main info gathering flow is completed, the outputs are sent to a join node, that assembles all your data back into an array with the same size and order as your original list of servers. This makes it nice and easy to compare data across servers, and to aggregate the data for analysis or storing in a database.
Sorry, no time to put together an example flow to demonstrate the concept - but I'm hoping this will spark some ideas. If you are still stuck, I can see about doing that this weekend.
global.set("hosts.openhabmain",
    {"hostname": "openhabmain",
    "hostip":"192.168.xx.xx",
let obj = global.get("hosts.openhabmain");
msg.url = obj.metricsurl;
msg.payload = obj.hostip;
node.send(msg);
I would store each source in its own object property, something like above.
then retrieve as below
    msg1.topic = "openHAB/master/snmp/" + global.get("hosts.openhubmain.hostname") + "/" + key;
    node.send(msg1)
You don't have to do all the heavy work for me! :wink:
So I did the following:
  1. configured the first function node with multiple outputs
  2. included my desired configration (hostname, hostip, metricsurl) in objects
  3. returned the objects seperately in each one of the outputs
  4. started the flows with outputs
looks like this:
var msg1 = {payload:{
var msg2 = {payload:{
return [ msg1, msg2 ];
then
msg.host = msg.payload.hostip;
msg.url = msg.payload.metricsurl;
msg.hostname = msg.payload.hostname;
msg.payload = "";
So I can re-use the msg.hostname later on, when I use that variable as part of the mqtt-topic:
    msg1.topic = "openHAB/master/snmp/" + msg.hostname + "/" + key;
for anyone interested here screenshot and flow again:
Summary
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "300",
        "crontab": "",
        "once": false,
        "onceDelay": "",
        "topic": "",
        "payload": "",
        "x": 150,
        "y": 580,
                "de4a1af6.4ae9b"
        "method": "GET",
        "ret": "txt",
        "paytoqs": "body",
        "url": "",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "x": 710,
        "y": 640,
                "344c1065.04ad48"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 400,
        "y": 740,
                "543607f4.df7328"
        "type": "json",
        "action": "obj",
        "pretty": true,
        "x": 600,
        "y": 740,
                "a65939ae.ad9d88"
        "type": "mqtt out",
        "topic": "",
        "qos": "1",
        "retain": "true",
        "x": 1130,
        "y": 740,
        "type": "function",
        "func": "for (let key in msg.payload){\n    let msg1 = {payload:{}};\n    // msg1.payload[key] = Object.assign(msg.payload[key],{\"key\":key});\n    msg1.payload = Object.assign(msg.payload[key]);\n    msg1.topic = \"openHAB/master/snmp/\" + msg.hostname + \"/\" + key;\n    node.send(msg1)\n}\nreturn;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 800,
        "y": 740,
                "462efda4.e53c84"
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "x": 990,
        "y": 740,
                "9aa67c3f.8ef998"
        "type": "function",
        "func": "var msg1 = {payload:{\n    \"hostname\": \"openhabmain\",\n    \"hostip\": \"192.168.xx.xx\",\n    \"metricsurl\": \"http://192.168.xx.xx:8080/rest/metrics/prometheus\"\n  }};\n\nvar msg2 = {payload:{\n    \"hostname\": \"openhabutilities\",\n    \"hostip\": \"192.168.yy.yy\",\n    \"metricsurl\": \"http://192.168.yy.yy:8080/rest/metrics/prometheus\"\n  }};\n\nreturn [ msg1, msg2 ];\n",
        "outputs": 2,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 210,
        "y": 640,
                "c19dafd9.60b7c8"
                "c19dafd9.60b7c8"
        "id": "c19dafd9.60b7c8",
        "type": "function",
        "func": "// JSON parsen\n// parsed = JSON.parse(msg.payload);\n\nmsg.host = msg.payload.hostip;\nmsg.url = msg.payload.metricsurl;\nmsg.hostname = msg.payload.hostname;\n\nmsg.payload = \"los1\";\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 480,
        "y": 640,
                "71173d2a.39309c"
        "name": "Synology",
        "port": "1883",
        "usetls": false,
        "keepalive": "60",
        "birthQos": "2",
        "closeQos": "2",
        "willQos": "2",
