how to create a global variable in python function
Hello
Can someone tell me how to create a global variable in a Python function
node-red-contrib-python-function
Node Red V3.1.3
Hello @Kleisi, welcome to the forum.
Can you explain why you want to do that?
Would it work to set the variable in a change node using the output of your python node?
Hello
I want to count signals or use calculations in other Python functions in other flows
and because I'm just interested :slight_smile:
I could be wrong,
But what you are trying to achieve is not possible.
Each python function node creates a new python process.
You don’t have the likes of global variables with this approach.
Like @jbudd says - use the Node RED globals to pass values to and from the python scripts.
But remember - the scripts are not in the same process as they are in Node RED
Or replace the python functions with node red flows.
There is a valuable and little known feature in Node-red for passing data between different flow tabs and internal & external processes: messages.
You can think of a message like a railway train. It travels along a prescribed track. At every stop different people and luggage can join the train and they are carried safely onward to their destination.
A context variable is a viable way to do this. But global context is ridiculous overkill. Use a variable whose scope is restricted to a flow or even a single node and put that value on the train for use further down the track.
A little javascript function to achieve this:
let signalCount = context.get("signalCount") || 0
signalCount += 1
context.set("signalCount", signalCount)
msg.signalCount = signalCount
return msg
