How to create function on rpi node red with two gpio - if gpio1 == 1 && gpio2 ==0 then gpio3=1
Have you done what I told you to do in the very first response in this thread?
Thanks to all of you who have responded to this issue. Maybe at the beginning I did not correctly describe the problem for which I apologize. In the end, I achieved the result I expected.
Special thanks to zenofmud and Colin. Thanks.
Here is the end result.
[{"id":"db1e7864.8ec9b8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"2b79041b.1cdbdc","type":"function","z":"db1e7864.8ec9b8","name":"","func":"if (msg.payload.gpio1 == 1 && msg.payload.gpio2 == 1) {\nmsg.payload = 1;\nreturn msg;\n}\nelse{\n msg.payload = 0;\nreturn msg;\n}\n\n ","outputs":1,"noerr":0,"x":490,"y":120,"wires":[["fe139b61.8e5248"]]},{"id":"fe139b61.8e5248","type":"debug","z":"db1e7864.8ec9b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":670,"y":120,"wires":[]},{"id":"19565d15.04c483","type":"inject","z":"db1e7864.8ec9b8","name":"gpio1 on","topic":"gpio1","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":160,"wires":[["2f810a4d.e5da16"]]},{"id":"2f810a4d.e5da16","type":"join","z":"db1e7864.8ec9b8","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":200,"wires":[["d7fb43c2.8024b","2b79041b.1cdbdc"]]},{"id":"d7fb43c2.8024b","type":"debug","z":"db1e7864.8ec9b8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":200,"wires":[]},{"id":"c7161e7f.1141d","type":"inject","z":"db1e7864.8ec9b8","name":"gpio2 on","topic":"gpio2","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":240,"wires":[["2f810a4d.e5da16"]]},{"id":"9d3d4ee9.66c38","type":"inject","z":"db1e7864.8ec9b8","name":"gpio1 off","topic":"gpio1","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":200,"wires":[["2f810a4d.e5da16"]]},{"id":"1cc91888.72de17","type":"inject","z":"db1e7864.8ec9b8","name":"gpio2 off","topic":"gpio2","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":280,"wires":[["2f810a4d.e5da16"]]}]
The joy was brief. With inject node everything is ok but in practice with hardware pins, things don't work out that way. The attached picture shows the messages on the right. look at functions in a flow. Help.Preformatted text
[{"id":"7bbf6c01.b26624","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"2db2a33b.dee8dc","type":"function","z":"7bbf6c01.b26624","name":"","func":"if (msg.payload.gpio1 == 1 && msg.payload.gpio2 == 1) {\nmsg.payload = 1;\nreturn msg;\n}\nelse{\n msg.payload = 0;\nreturn msg;\n}\n\n ","outputs":1,"noerr":0,"x":490,"y":120,"wires":[["e7762b1.e6959d8"]]},{"id":"e7762b1.e6959d8","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":690,"y":120,"wires":[]},{"id":"cf592dd9.6aa23","type":"inject","z":"7bbf6c01.b26624","name":"gpio1 on","topic":"gpio1","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":160,"wires":[["c1ee0201.be6d9"]]},{"id":"c1ee0201.be6d9","type":"join","z":"7bbf6c01.b26624","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":200,"wires":[["2257545a.9ea27c","2db2a33b.dee8dc"]]},{"id":"2257545a.9ea27c","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":200,"wires":[]},{"id":"7bddbf31.4d53b","type":"inject","z":"7bbf6c01.b26624","name":"gpio2 on","topic":"gpio2","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":240,"wires":[["c1ee0201.be6d9"]]},{"id":"b6bb8a6.b792678","type":"inject","z":"7bbf6c01.b26624","name":"gpio1 off","topic":"gpio1","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":200,"wires":[["c1ee0201.be6d9"]]},{"id":"50bd9c40.c68974","type":"inject","z":"7bbf6c01.b26624","name":"gpio2 off","topic":"gpio2","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":280,"wires":[["c1ee0201.be6d9"]]},{"id":"407a809e.71686","type":"rpi-gpio in","z":"7bbf6c01.b26624","name":"","pin":"37","intype":"up","debounce":"25","read":false,"x":160,"y":340,"wires":[["384d8adf.464636"]]},{"id":"5efa9c17.e96944","type":"rpi-gpio in","z":"7bbf6c01.b26624","name":"","pin":"35","intype":"up","debounce":"25","read":false,"x":160,"y":400,"wires":[["384d8adf.464636"]]},{"id":"db5c91e3.4380c","type":"function","z":"7bbf6c01.b26624","name":"","func":"if (msg.payload.pi/35 == 1 && msg.payload.pi/37 == 1) {\nmsg.payload = 1;\nreturn msg;\n}\nelse{\n msg.payload = 0;\nreturn msg;\n}\n\n ","outputs":1,"noerr":0,"x":490,"y":320,"wires":[["8c2e7942.8a9ef8"]]},{"id":"8c2e7942.8a9ef8","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":650,"y":320,"wires":[]},{"id":"384d8adf.464636","type":"join","z":"7bbf6c01.b26624","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":330,"y":380,"wires":[["11365f4b.9ab771","db5c91e3.4380c"]]},{"id":"11365f4b.9ab771","type":"debug","z":"7bbf6c01.b26624","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":610,"y":380,"wires":[]}]
Please review my last post. I made a mistake again. Thanks.
Ah the joy of javascript....
your combined payloads look like this
all good so far
Then your function does this
which is a natural thing to do... but javascript doesn't like / in property names so it will be treating it like a divide :-)... so instead you need to do
if (msg.payload["pi/35"] == 1 && msg.payload["pi/37"] == 1) {
Now another problem has arisen. After deploy does not check the status of the pins and even if they are 1 or "high" msg.payload is 0. how to update this information after deploy to read real readings from pins?
Thanks.
If you do a full deploy then I think it should give you the initial status. If you do a partial deploy not including the i/o nodes then they do not know to send the data.
Thanks for all the answers, for other questions I will look for a solution and open a new topic
