Simple if loop statement
I'm very new to Node-Red, and I'm also very knew to programming. I'm currently using the function node to write the following:
if (msg.payload.pi/11 === 0){
msg.payload = 1;
} else {
msg.payload = 2;
It appears the problem lies with the /11 part and it should be something like
if (msg.payload.match ( ) === 0){
msg.payload = 1;
} else {
msg.payload = 2;
My problem is that I don't know what to write inside the ( ) of the match part. Does it have to be some sort of JSON expression?
I'm getting this output (msg.payload.pi/11) from a rpi gpio in node that outputs a digital signal out of pin 11 from a raspberry pi.
Thanks for your help.
If you look at the info tab of the rpi-gpio in node you will see the following
Outputs
payload number
the payload will be a 1 or a 0.
topic string
the topic will be set to
pi/{the pin number} .
so you want to test msg.payload. If you want to check what pin returned the message, then you would be looking at msg.topic.
You should take a few minutes to read thru the section in the documentation https://nodered.org/docs/user-guide/messages
which should help you understand how to work with the contents of messages.
And welcone to the forum :fireworks:
