Is there some way to debug a non-working serial connection? The gateway (Eltako FGW14-USB) remains silent.
Is that a USB/RS485 adaptor?
When you mean it is silent do you mean that you have put a scope on the outputs and there is no data?
Does it work if you use different software to drive the serial port?
@Colin, as per your suggestion, I wrote the following python program. It switches on a light, i.e. the USB/RS485 adapter works,
import serial as s
import time
ser = s.Serial()
ser.port = '/dev/ttyUSB0'
ser.open
while ser.isOpen():
input('Error: Ser is already open, please close it manually. if the port is closed, press enter\n')
try:
ser.close()
except serial.serialutil.PortNotOpenError:
pass
ser.open()
b1 = bytearray.fromhex('a5 5a 0b 05 30 00 00 00 ff e7 af c0 30 c5')
ser.write(b1)
So, then the question is that why the following doesn't do the same.
"id": "a4f4870704c37208",
"type": "inject",
"z": "21791ddc4a0ad0ab",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "'a5 5a 0b 05 30 00 00 00 ff e7 af c0 30 ff'",
"payloadType": "str",
"x": 110,
"y": 540,
"c5de03e978ce6e02",
"7806e797fa467d7a"
"id": "c5de03e978ce6e02",
"type": "debug",
"name": "debug 23",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"statusType": "auto",
"x": 320,
"y": 480,
"id": "7806e797fa467d7a",
"type": "serial out",
"serial": "c498c0f59b8c57ec",
"x": 330,
"y": 540,
"id": "c498c0f59b8c57ec",
"type": "serial-port",
"serialport": "/dev/ttyUSB0",
"serialbaud": "9600",
"databits": "8",
"parity": "none",
"stopbits": "1",
"waitfor": "",
"dtr": "none",
"rts": "none",
"cts": "none",
"dsr": "none",
"newline": "14",
"bin": "bin",
"out": "count",
"addchar": "",
"responsetimeout": "100"
You need to inject a buffer if that is what you want to send
currently you have it set to inject a string.
[{"id":"a4f4870704c37208","type":"inject","z":"27d4cd61f8c2d5ed","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[\"0xa5\",\"0x5a\",\"0x0b\",\"0x05\",\"0x30\",\"0x00\",\"0x00\",\"0x00\",\"0xff\",\"0xe7\",\"0xaf\",\"0xc0\",\"0x30\",\"0xff\"]","payloadType":"bin","x":150,"y":160,"wires":[["c5de03e978ce6e02","7806e797fa467d7a"]]},{"id":"c5de03e978ce6e02","type":"debug","z":"27d4cd61f8c2d5ed","name":"debug 23","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":360,"y":100,"wires":[]},{"id":"7806e797fa467d7a","type":"serial out","z":"27d4cd61f8c2d5ed","name":"","serial":"c498c0f59b8c57ec","x":370,"y":160,"wires":[]},{"id":"c498c0f59b8c57ec","type":"serial-port","serialport":"/dev/ttyUSB0","serialbaud":"9600","databits":"8","parity":"none","stopbits":"1","waitfor":"","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"14","bin":"bin","out":"count","addchar":"","responsetimeout":"100"}]
