How to delete message parts in function node
I know the change node allows you to delete parts of a message.
What command do I use in a function node to get the same thing done?
Thanks.
Have a read of this and see if you apply it to individual properties.
https://nodered.org/docs/user-guide/writing-functions
Example:
msg.topic = null;
@bobo Thanks. Looking.
@krambriw Yeah, and the msg. still have those properties listed in the debug window (or next node) when it arrives.
I would prefer to not have them listed at all.
Then
delete msg.topic;
Would you like to elaborate on that?
I'm stupid.
I admit it.
I don't know if the command delete msg.foo exists.
Yeah, ok: I maybe should have tried it before posting. See above.
Shall try soon.
I try always BEFORE I post :wink:
Then you are better then me. What can I say?
You are still trying to learn,,,,the same as I do !!!
No worries, it aint easy all the things to handle, I know, just realized this after upgrade to 1.0
I'm not going there yet. Too scared of what I may find.
If the stuff you have today aint working yet, you better fix that first before upgrading, at least I think so. If you have used a lot of code in function nodes, you should really look into how you wrote that code. We had discussions about that, maybe you noticed?
Yeah, well...... That's a whole other thing.
I am now re-writing a lot of code to make it nicer/better/(something else) so it is of higher quality.
I think that is 100% ongoing as there is no defined layout of what is wanted.
As I am writing, I see other/better ways of doing things and over 10 RPIs and 2 NUCs, it is painful when I have 2/3's of NO PROGRAMMING KNOWLEDGE.
All this started less than 3 years ago.
NR probably less than 2.
I think, coming back to the topic, this is a better example for you (using code in function nodes). You can run it and study the differences in the msg sent to debug
[{"id":"32ac6a9a.e0dc56","type":"inject","z":"60f50465.20a53c","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":700,"y":100,"wires":[["b4e5c41d.c24248"]]},{"id":"b824f72c.176208","type":"function","z":"60f50465.20a53c","name":"","func":"node.warn(msg);\ndelete msg.payload.Who;\nreturn msg;","outputs":1,"noerr":0,"x":1070,"y":100,"wires":[["f6e4cc5d.086d4"]]},{"id":"f6e4cc5d.086d4","type":"debug","z":"60f50465.20a53c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1230,"y":100,"wires":[]},{"id":"b4e5c41d.c24248","type":"function","z":"60f50465.20a53c","name":"","func":"msg = {\"topic\":null,\"host\":null,\"_msgid\":\"a2c057de.049818\",\"_topic\":null,\"payload\":{\"Who\":\"TimePi\",\"device\":\"UpLink\",\"UpLink\":\"Online\"},\"_event\":\"node:97bcd5bc.1a76e8\",\"condition\":\"Online\"};\nreturn msg;","outputs":1,"noerr":0,"x":880,"y":100,"wires":[["b824f72c.176208","9caca000.d752f"]]},{"id":"9caca000.d752f","type":"debug","z":"60f50465.20a53c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1070,"y":170,"wires":[]}]
Thanks.
I indulged your suggestion and just put the line
delete msg.(what ever part);
And it is deleted.
