How to download and use bluetooth node?
I'm trying to download any 'BLE node' in palette.
I want to use BLE node in my node-red. I know i can use BLE node with RED-Mobile but
I want to control BLE devices with my PC. That's why i need BLE node.
There's many nodes for BLE but i can't download any of them.
I want to use one of these nodes but i cant' download anything.
This is explanation about the node which i want to use.
This is the node's explanation link
2022-10-07T03:48:13.094Z 설치 : node-red-contrib-noble-bluetooth 0.9.1
2022-10-07T03:48:13.442Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-noble-bluetooth@0.9.1
2022-10-07T03:48:22.668Z [err] npm
2022-10-07T03:48:22.669Z [err]  ERR! code 1
2022-10-07T03:48:22.669Z [err] npm ERR! path C:\Users\admin\.node-red\node_modules\@abandonware\noble
2022-10-07T03:48:22.671Z [err] npm ERR! command failed
2022-10-07T03:48:22.671Z [err] npm ERR! command C:\Windows\system32\cmd.exe /d /s /c node-gyp rebuild
2022-10-07T03:48:22.671Z [err] npm ERR! gyp info it worked if it ends with ok
2022-10-07T03:48:22.671Z [err] npm ERR! gyp info using node-gyp@8.3.0
2022-10-07T03:48:22.671Z [err]  gyp info using node@16.13.1 | win32 | x64
2022-10-07T03:48:22.671Z [err] npm ERR! gyp info find Python using Python version 3.10.7 found at "C:\Users\admin\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\python.exe"
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS msvs_version not set from command line or npm config
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS unknown version "undefined" found at "C:\Program Files\Microsoft Visual Studio\2022\Community"
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
2022-10-07T03:48:22.671Z [err] ERR! gyp ERR! find VS looking for Visual Studio 2015
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS - not found
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
2022-10-07T03:48:22.671Z [err]  gyp ERR! find VS
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS **************************************************************
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS You need to install the latest version of Visual Studio
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS including the "Desktop development with C++" workload.
2022-10-07T03:48:22.671Z [err] ERR! gyp ERR! find VS For more information consult the documentation at:
2022-10-07T03:48:22.671Z [err] npm ERR! gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
2022-10-07T03:48:22.672Z [err]  gyp ERR! configure error
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack Error: Could not find any Visual Studio installation to use
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
2022-10-07T03:48:22.672Z [err] ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at ChildProcess.exithandler (node:child_process:404:5)
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:390:28)
2022-10-07T03:48:22.672Z [err] ERR! gyp ERR! stack     at maybeClose (node:internal/child_process:1064:16)
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! System Windows_NT 10.0.19044
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
2022-10-07T03:48:22.672Z [err]  gyp ERR! cwd C:\Users\admin\.node-red\node_modules\@abandonware\noble
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! node -v v16.13.1
2022-10-07T03:48:22.672Z [err] npm ERR! gyp ERR! node-gyp -v v8.3.0
2022-10-07T03:48:22.672Z [err] ERR! gyp ERR! not ok
2022-10-07T03:48:22.681Z [err]
2022-10-07T03:48:22.681Z [err] npm ERR! A complete log of this run can be found in:
2022-10-07T03:48:22.681Z [err] npm ERR!     C:\Users\admin\AppData\Local\npm-cache\_logs\2022-10-07T03_48_22_673Z-debug.log
2022-10-07T03:48:22.699Z rc=1
2022-10-07T03:54:00.838Z 설치 : node-red-contrib-noble-bluetooth 0.9.1
2022-10-07T03:54:00.842Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-noble-bluetooth@0.9.1
2022-10-07T03:54:11.246Z [err] npm
2022-10-07T03:54:11.246Z [err]  ERR! code 1
2022-10-07T03:54:11.246Z [err] path C:\Users\admin\.node-red\node_modules\@abandonware\noble
2022-10-07T03:54:11.249Z [err] npm ERR! command failed
2022-10-07T03:54:11.249Z [err] npm ERR! command C:\Windows\system32\cmd.exe /d /s /c node-gyp rebuild
2022-10-07T03:54:11.249Z [err]  gyp info it worked if it ends with ok
2022-10-07T03:54:11.249Z [err] npm ERR! gyp info using node-gyp@8.3.0
2022-10-07T03:54:11.249Z [err]  gyp info using node@16.13.1 | win32 | x64
2022-10-07T03:54:11.249Z [err] npm ERR! gyp info find Python using Python version 3.10.7 found at "C:\Users\admin\AppData\Local\Microsoft\WindowsApps\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\python.exe"
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! find VS
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! find VS msvs_version not set from command line or npm config
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
2022-10-07T03:54:11.249Z [err] ERR! gyp ERR! find VS unknown version "undefined" found at "C:\Program Files\Microsoft Visual Studio\2022\Community"
2022-10-07T03:54:11.249Z [err]  gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! find VS looking for Visual Studio 2015
2022-10-07T03:54:11.249Z [err]  ERR! gyp ERR! find VS - not found
2022-10-07T03:54:11.249Z [err]  gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
2022-10-07T03:54:11.249Z [err]  ERR! gyp ERR! find VS **************************************************************
2022-10-07T03:54:11.249Z [err]  gyp ERR! find VS You need to install the latest version of Visual Studio
2022-10-07T03:54:11.249Z [err]  gyp ERR! find VS including the "Desktop development with C++" workload.
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! find VS For more information consult the documentation at:
2022-10-07T03:54:11.249Z [err]  ERR! gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
2022-10-07T03:54:11.249Z [err]  gyp ERR! find VS **************************************************************
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! configure error
2022-10-07T03:54:11.249Z [err] ERR! gyp ERR! stack Error: Could not find any Visual Studio installation to use
2022-10-07T03:54:11.249Z [err]  gyp ERR! stack     at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
2022-10-07T03:54:11.249Z [err]  ERR! gyp ERR! stack     at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
2022-10-07T03:54:11.249Z [err]  gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
2022-10-07T03:54:11.249Z [err] npm ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
2022-10-07T03:54:11.249Z [err] ERR! gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
2022-10-07T03:54:11.250Z [err]  gyp ERR! stack     at ChildProcess.exithandler (node:child_process:404:5)
2022-10-07T03:54:11.250Z [err] npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:390:28)
2022-10-07T03:54:11.250Z [err]  ERR! gyp ERR! stack     at maybeClose (node:internal/child_process:1064:16)
2022-10-07T03:54:11.250Z [err]  gyp ERR! System Windows_NT 10.0.19044
2022-10-07T03:54:11.250Z [err] npm ERR! gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
2022-10-07T03:54:11.250Z [err] npm ERR! gyp ERR! cwd C:\Users\admin\.node-red\node_modules\@abandonware\noble
2022-10-07T03:54:11.250Z [err]  gyp ERR! node -v v16.13.1
2022-10-07T03:54:11.250Z [err] npm ERR! gyp ERR! node-gyp -v v8.3.0
2022-10-07T03:54:11.250Z [err] npm ERR! gyp ERR! not ok
2022-10-07T03:54:11.259Z [err]
2022-10-07T03:54:11.259Z [err] npm ERR! A complete log of this run can be found in:
2022-10-07T03:54:11.259Z [err] npm ERR!     C:\Users\admin\AppData\Local\npm-cache\_logs\2022-10-07T03_54_11_251Z-debug.log
2022-10-07T03:54:11.277Z rc=1
I already have Visual Studio 2022 but i don't know why this error message appeared.
I can't find any information about this in Google. Anyone knows about it?
Reagrds.
If you search the forum for gyp ERR! find VS - not found you will find many results.
Do you have your own idea about this?
Hi there, did you find a fix around this thing?
No sir. Nothing has changed.
