How to enable update notifications?
My main Node-red server has v4.1.4.
The telemetry section of settings.js looks like this
telemetry: {
         * By default, telemetry is disabled until the user provides consent the first
         * time they open the editor.
         * The following property can be uncommented and set to true/false to enable/disable
         * telemetry without seeking further consent in the editor.
         * The user can override this setting via the user settings dialog within the editor
        enabled: true,
         * If telemetry is enabled, the editor will notify the user if a new version of Node-RED
         * is available. Set the following property to false to disable this notification.
         updateNotification: true    // Also tried with this commented out
It does show me available updates for nodes
But nether before nor after updating the nodes does it show that NR 4.1.6 is available.
What am I missing?
You likely denied previously so try editing (or deleting) .config.runtime.json
Key name is telemetryEnabled
Hmm.
.config.runtime.json did indeed contain enableTelemetry: false (or similar) but neither changing it to true nor deleting the file, and restarting Node-red restored the notification.
Rebooting the Pi broke my network...
However now I see
Thanks Steve.
Just to add, the telemetry ping happens 30mins after Node-RED starts and every 24 hrs after that. So the notification won't appear instantly on a just-started instance.
