How to establish a profinet connection using node node-red-contrib-s7
node-red-contrib-s7 uses the s7 protocol
From a web search:
The S7 protocol is designed for transfering data into SCADA systems via Ethernet. The PROFINET protocol is used for communication between PLCs and IO modules . The S7 protocol can be used for communication via PROFINET connector in the PLC device or in add-on communication modules
