How to get flow id by function node
how to get flow id by function node?
the way get node id:
nodered1
hao to get flow id , nobody know it ?
:thinking:
The flow id is not available in the function.
This was asked a few months ago and someone shared a flow that used the admin http API to get the flow configuration and, from that, find the flow id. If you search the forum you may be able to find it.
thank you very much
Probably something like below:
[{"id":"c6102b2d.d908e8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"dda94d1c.3a07a","type":"change","z":"c6102b2d.d908e8","name":"jsonata filter","rules":[{"t":"set","p":"filter","pt":"msg","to":"payload[type = 'tab']","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":140,"wires":[["f5dc667c.ac8108"]]},{"id":"1624601c.23f32","type":"inject","z":"c6102b2d.d908e8","name":"","topic":"flows","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":140,"wires":[["312ff7a6.7dd008"]]},{"id":"f5dc667c.ac8108","type":"debug","z":"c6102b2d.d908e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"filter","targetType":"msg","x":600,"y":140,"wires":[]},{"id":"312ff7a6.7dd008","type":"http request","z":"c6102b2d.d908e8","name":"Get {{{topic}}}","method":"GET","ret":"obj","paytoqs":false,"url":"http://localhost:1880/{{{topic}}}","tls":"","proxy":"","authType":"basic","x":260,"y":140,"wires":[["dda94d1c.3a07a"]]}]
thank you very much :heart_eyes:
勉強になりました
