How to get node red logs as a text file
Hi all
I can saw the logs in command promt but i want that logs as a file fo debugging
please let me know how to do that
thanks
How are you running Node-RED?
by using node-red command
Using what operating system?
If you are just typing the command node-red to run it, then you have to manually redirect its log output to a file.
For example:
node-red > node-red-log.txt
