How to get path params from http post url. e.g. http://nodered:1880/post/{name}. I am trying through
msg.req.name
but its not working.
msg.req.name
It is not cleare whether you are talking about the http in node or request node. I presume the in node.
From the sidebar help text of the http in node.
The node will listen on the configured path for requests of a particular type. The path can be fully specified, such as
/user, or include named parameters that accept any value, such as/user/:name. When named parameters are used, their actual value in a request can be accessed undermsg.req.params.
msg.req.params giving undefined error when I am using node.warn()
And how are you setting the path in the http in node config?
it should be /post/:name
Use a debug node and set it to complete msg output to see what you are actually posting in the params.
There is an example in the Node-red website Cookbook that you can import and study
