Hi community
I'm new to node-red and try to config a simple http endpoint (REST API). I startet adapt with the samples from the cookbook: this one with one single parameter works fine (https://cookbook.nodered.org/http/handle-url-parameters). Now i wanted to pass 2 or more parameters. So I try to adapt this example.
But in my case it only accepts the first parameter:
api.mydomain.cloud/api/cm/v1/getdoglistbysearch?clientid=1234&query=test
api.mydomain.cloud/api/cm/v1/getdoglistbysearch?query=test&clientid=1234
I read the values with msg.req.query.query and msg.req.query.clientid
Do i have adapt the example wrong with 2 or more parameters?
Daniel
