How to get single record from select query..?
Hello All,
I want to get single record from select query.... i am getting output in object..?
I'm writing query in function like this
msg.topic= "select body from test limit 1;"
i am getting this output
array[1]
0: object
body: "SI,310720,054307,1831.9042,N,07356.2427,E,61.01,0,1,0.0,A"
i want value of body in variable ... because i have to pass that value in another query.
What node are ou using? Did you check the node's options to see if it can return one msg per record?
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
Or move the item to where you want it using a change node.
[{"id":"7d33b77c.2dfdd8","type":"inject","z":"8d22ae29.7df6d","name":"","props":[{"p":"payload[0]","v":"{\"body\": \"SI,310720,054307,1831.9042,N,07356.2427,E,61.01,0,1,0.0,A\"}","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":2020,"wires":[["53535fbb.5abe6"]]},{"id":"53535fbb.5abe6","type":"change","z":"8d22ae29.7df6d","name":"","rules":[{"t":"move","p":"payload[0].body","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":2020,"wires":[["2a105b6e.c8af14"]]},{"id":"2a105b6e.c8af14","type":"debug","z":"8d22ae29.7df6d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":2020,"wires":[]}]
PFA
I am using function and mysql node .
in function node i write select query.
feed it into a split node
how..if possible can you give example..?
You've already been given an example by @E1cid for using a Change node to move the property you want to where you need it. Import that flow and see what it does.
