I'm using an OR node, configured as XOR, from the node-red-contrib-bool-gate palette. It's comparing the msg.payload.value of 2 inputs, and the output of the XOR node only shows the input states in debug. Right under the XOR node is the boolean TRUE and FALSE state that updates correctly but I can't find it in the debug output. How can I find/use the boolean state?
Set the debug up to show the full message object.
Got it, thanks for the quick reply.
