I'm creating a custom node, and for my UI I want to have a group of checkboxes for the user to select. When a checkbox is selected/deselected, I want this to toggle an array index corresponding to the checkbox's value, in the custom node's JS file to either 1 or 0. My issue is, I cannot figure out how to transmit the state of the checkboxes from the UI.
I've tried the method outlined here: Node properties : Node-RED, but it doesn't seem to be updating the properties. Ideally, I would pass a JSON object as a config property, containing information on whether each checkbox is toggled on/off. I would appreciate any pointers on how to go about this.
Hi @cookies - welcome to the forums!
Not sure I follow.
Given the below property definition
defaults: {
myCheckBox: {
value: false
And the following node config UI component
<div class="form-row">
<label for="node-input-myCheckBox" style="width:130px"><i class="fa fa-pencil"></i> myCheckBox </label>
<input type="checkbox" id="node-input-myCheckBox">
</div>
it will stay in sync, so when opening up the node properties the checkbox will will restore their correct state.
you can then obtain these properties in your module via
function Init(config) {
RED.nodes.createNode(this, config);
config.myCheckBox
What @marcus-j-davies says
Alternatively,
use oneditsave callback to read the checkboxes and store them in this.checkboxes array. NOTE: checkboxes would need to be defined in the defaults .
To echo the answer by @Steve-Mcl - the below should cater for it.
The definition and necessary callbacks.
RED.nodes.registerType('my-module', {
defaults: {
bits: {
value: []
oneditsave: Save,
oneditprepare: Restore
function Save() {
const NumCheckBoxes = 3;
this.bits = [];
for (let i = 0; i < NumCheckBoxes; i++) {
this.bits.push($(`#CheckBoxIndex_${i}`).is(":checked"));
function Restore() {
for (let i = 0; i < this.bits.length; i++) {
$(`#CheckBoxIndex_${i}`).prop('checked', this.bits[i]);
And the HTML. No need for the node-input- ID prefix, as they are not directly associated with a config definition.
<label for="CheckBoxIndex_0" style="width:130px"><i class="fa fa-pencil"></i> CheckBox 1</label>
<input type="checkbox" id="CheckBoxIndex_0">
</div>
<label for="CheckBoxIndex_1" style="width:130px"><i class="fa fa-pencil"></i> CheckBox 2</label>
<input type="checkbox" id="CheckBoxIndex_1">
</div>
<label for="CheckBoxIndex_2" style="width:130px"><i class="fa fa-pencil"></i> CheckBox 3</label>
<input type="checkbox" id="CheckBoxIndex_2">
</div>
Then, in your module
config.bits[0] will yield true | false for checkbox 1
