It seems that the dashboard code automatically handles some aspects of class for third party nodes. I am unclear what the recommended way of handling class is, such that I can provide a class field in the widget, and a msg.class passed in will get appended as an extra class to the widget (which I assume is what is wanted). Also, should msg.ui_update.class append to or replace the class in the widget setup?
As an example, the ui-text node does NOT implement anything at all for className but if you add a className value to a ui-text, it gets applied to the class list.
It should just work by virtue of you adding the className prop to the node defaults.
OK, the className field in the config is getting to the DOM ok.
However, if I send in a class using msg.class then nothing happens immediately. If I refresh the page then it is picked up. It seems I have to put something in my server side to pickup the class from the message, and put it somewhere.
I would implement what you have (class support via edit form) and raise an issue around seamless support in the core project for dynamic class update (unless @joepavitt has some other words of wisdom)
I was wrong stating that it didn't work at all. msg.ui_update.class does add the class at the server end, but, as with msg.class, it doesn't get inserted into the DOM until a page refresh.
At the client I can see that on page refresh the class is passed in props.class so I tried in the client
if ("class" in msg) {
console.log(`setting props.class to ${msg.class}`)
this.props.class = msg.class
and I can see that it does set props.class, but it doesn't have any effect on the DOM.
I have hacked it for the moment by also explicitly including props.class in the outer div, and that does work, but it is wasteful as on a page refresh the class now appears twice.
I will wait a bit for Joe to respond and submit an issue if necessary.
