How to humanize date&time format in array of objects?
Hi all,
please could someone help me, how to humanize "created" property (for example: YYYY-MM-DD HH:mm) in whole array of objects on screenshot?
It is output of MySQL node.
Many thanks.
Try a function node with ..
msg.payload.forEach(e => {
  e.created = (new Date(e.created)).toString();
I suspect this one is better suited to a change node & moment in JSONata
(Untested, written on mobile)
or do the Date convertion directly in mySql query using DATE_FORMAT(date , format )
For Example
SELECT *, DATE_FORMAT(created, '%Y-%m-%d %H:%i:%s') as created FROM events ORDER BY id DESC LIMIT 50)
Thank you, I like this solution.
