Hi All,
I am trying to do POC n8n for a workflow process.
Let’s say there is a Web application for shipment creation. Once a shipment is created it has its own life cycle as mentioned below:
Shipment Request Creation
In this step, a user fills out a form to create a request in a web application, and from the backend API service, I would like to trigger a workflow that contains Shipment Request Creation node. The trigger will have a JSON payload of a shipment request. -
Shipment update ERP
Post the output of the previous node to the ERP system.
For this step, I could use the HTTP Request node.
Step 1 and Step 2 will happen immediately once the workflow is triggered.
- Vehicle Assignment
In this step, a user fills vehicle details against a specific shipment request in a web application, and from the backend API service, I would like to trigger a workflow that contains Vehicle Assignment node. The trigger will have a JSON payload of a shipment request.
This step should get executed only when user action happens at other web applications and how to create a custom node which should wait for such trigger.
- Truck-In
In this step, a user fills truck details during entry to the factory against a specific shipment request in a web application, and from the backend API service, I would like to trigger a workflow that contains Truck In node. The trigger will have a JSON payload of a shipment request.
- Truck Out
In this step, a user fills truck details during exit from the factory against a specific shipment request in a web application, and from the backend API service, I would like to trigger a workflow that contains Truck Out node. The trigger will have a JSON payload of a shipment request.
- Shipment Provision to ERP
For this step, I could use the HTTP Request node and can execute it immediately after the previous node execution.
- Proof of Delivery
In this step, a user fills delivery details against a specific shipment request in a web application, and from the backend API service, I would like to trigger a workflow that contains Proof of Delivery node. The trigger will have a JSON payload of a shipment request.
Vehicle Assignment, Truck-In, Truck Out, Proof of Delivery are needs to be wait nodes in a single workflow and should be able to trigger via HTTP requests from other applications.
Please refer to the attached image for understanding the flow.
Thanks Swapnil Satpathy
