bro by using this way
SET @val1= '{{{msg.payload[0]}}}';
SET @val2= '{{{msg.payload[1]}}}';
null data is adding into database.
you need to put debug nodes before and after like i've said several times now
also, it may be...
SET @val1= '{{{payload[0]}}}';
SET @val2= '{{{payload[1]}}}';
check the built in help on the MSSQL-PLUS node - it gives you examples.
I have a feeling msg part is not required when accessing msg properties in {{{mustache}}}
Only needed for {{{flow.xxx}}} and {{{global.xxx}}}
