How to insert an array into mssql?
DECLARE @val1 NVARCHAR(MAX)
DECLARE @val2 NVARCHAR(MAX)
DECLARE @myVal NVARCHAR(MAX)
SET @myVal={{{msg.payload}}};
SET @val1= myVal[0];
SET @val2= myVal[1];
INSERT INTO SPLT
VALUE1,
VALUE2
VALUES
@val1,
'value'
im getting some syntax error. anyone please help.
Hi Bilal. Please export your flow and add it here by using the </> button you see in the post editor. Next, add the error you are getting. We are unable to help you without any of these information.
Also please add your Node-RED version, NodeJS version and the name of the custom node for mssql you are using.
My bet would be @val1 is empty OR its a string and you need ' single quotes around @val1.
If you are using node-red-contrib-mssql-plus then attach a debug node after the MSSQL node (with the debug node set to output complete msg object`).
Then in the debug window, have a look at what is in msg.query (msg.query will contain the final SQL ran against the SQL server)
Node red version : v0.20.7
Node.js version: v10.16.2
Here is my nodes:
[{"id":"7888aca5.823a44","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"22aa6555.667b9a","type":"inject","z":"7888aca5.823a44","name":"","topic":"message","payload":"Bilal,Mustafa","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":180,"wires":[["b7873ce4.b2385"]]},{"id":"117859aa.6ce246","type":"debug","z":"7888aca5.823a44","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":550,"y":120,"wires":[]},{"id":"649a41e6.78c85","type":"MSSQL","z":"7888aca5.823a44","mssqlCN":"b63f32ce.fe4a3","name":"","query":"DECLARE @val1 NVARCHAR(MAX)\nDECLARE @val2 NVARCHAR(MAX)\nDECLARE @myVal NVARCHAR(MAX)\n\nSET @myVal='{{{payload}}}';\nSET @val1= myVal[0];\nSET @val2= myVal[1];\n\nINSERT INTO SPLT\n    (\n        VALUE1,\n        VALUE2\n    )\n    VALUES\n    (\n        @val1,\n        'value'\n    )\n","outField":"payload","x":350,"y":260,"wires":[["117859aa.6ce246"]]},{"id":"b7873ce4.b2385","type":"function","z":"7888aca5.823a44","name":"splitFun","func":"var myMsg= msg.payload;\nmsg.payload=myMsg.split(\",\");\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":100,"wires":[["649a41e6.78c85","117859aa.6ce246"]]},{"id":"b63f32ce.fe4a3","type":"MSSQL-CN","z":"","name":"pme-57","server":"pme-57.cxzip7yq152r.ap-south-1.rds.amazonaws.com","encyption":false,"database":"test2"}]
bro i'm splitting Bilal,Mustafa using split function. here is my function's code:
msg.payload=myMsg.split(",");
in which case its a string and you need single quotes in your SQL values around the @val1.
EDIT ^ ignore that
Again...
If you are using node-red-contrib-mssql-plus then attach a debug node after the MSSQL node (with the debug node set to output complete msg object). Then in the debug window, have a look at what is in msg.query` (msg.query will contain the final SQL ran against the SQL server)
same error again and again
RequestError: Incorrect syntax near '1'.
are you using node-red-contrib-mssql-plus?
If so, do what I said and see what the final SQL is being sent to the SQL Server.
bro i'm using node-red-contrib-mssql.
should i use node-red-contrib-mssql-plus???
ah man...
you cant do that haha
try...
SET @val1= {{{msg.payload[0]}}};
SET @val2= {{{msg.payload[1]}}};
yes. (IMHO) it is much more comprehensive and fixes some bugs like querying wrong SQL Server when more than one config & it has much more features like throwing errors, additional outputs (to help in situations like this) & more.
getting a new error hahahah
RequestError: Incorrect syntax near ';'.
here is my query:
--DECLARE @myVal NVARCHAR(MAX)
--SET @myVal={{{payload}}};
INSERT INTO SPLT
        VALUE1,
        VALUE2
    VALUES
        @val1,
        @val2
that's great i'll use it...
are you certain msg.payload IS AN ARRAY?
put a debug node BEFORE the MSSQL to and inspect msg.payload
TBH, I never tried accessing [array elements] inside {{{mustache}}}.
If thats the issue then maybe add a change node BEFORE MSSQL to set msg.val1 to msg.payload[0] and set msg.val2 to msg.payload[1]
then use {{{msg.val1}}} in the SQL.
Install the mssql-plus node & debug the output - this will be far easier to fix.
yes i have array in msg.payload.
having same error....
anyone can help me or guide me a syntax for adding array into db.
post a screen shot and copy/paste the text from the debug output of MSSQL-PLUS (debug node output set to full msg object)
In particular, I want to see msg.query
Be sure to set the debug node to show full object
Edited the title to something more descriptive.
Actually, as the mustache is converted to text, you will need SQL compatable quotes around that part too...
SET @val1= '{{{msg.payload[0]}}}';
SET @val2= '{{{msg.payload[1]}}}';
