Hello, i am trying to insert multiple data into a mysql database but i am unable to insert them into the correct field here is my flow diagram
here is how i've written my node function...
msg.topic="INSERT Into fire_contents (Temperature1) values(?)";
msg.payload=[msg.payload];
(Temperature1,Temp2) and (?,?) would allow me to insert data into two columns
but i dont understand how to insert the data into the correct columns or order
Did you try a search of the forum to see if others have had similar questions? (hint hint)
i checked but i didn't get through
When you say "i checked but i didn't get through" what do you mean?
Someone was doing something similar to what i was doing. He got a suggestion how to fix it put he didn't respond after the suggestion so i dont know if the problem was solved or not...
did you try the suggesstion he got?
Where can I find this post which propably will have the answer I need?
Seeing that this thread is a year old, please opens new thread with your issue.
Meanwhile I’ll close this thread
