How to list files and parse them
Hi, now I have two problems:
1) var publicVariables = {
    Data_START: "00:00:00", //this generate an error, I assume because it's not recognized as an hour
    Lotto_START: "0",
    Scheda_START: "0"
global.set("publicVariables", publicVariables);
  1. No Output of payload with Calcola_Tempo calculated with:
var Calcola_Tempo = (msg.payload.Ora - publicVariables.Data_START);
This is the flow
[{"id":"98a22fb9.cb5a","type":"file in","z":"b1118599.3545f8","name":"Apri LOG DVC","filename":"","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":340,"y":280,"wires":[["a25570de.29aed"]]},{"id":"ab3cd84c.703898","type":"change","z":"b1118599.3545f8","name":"C:\\LOG_QUADRA\\Storico","rules":[{"t":"set","p":"path","pt":"msg","to":"\\\\10.0.0.4\\c$\\LOG_QUADRA\\","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":220,"wires":[["91d240da.015f8"]]},{"id":"91d240da.015f8","type":"fs-ops-dir","z":"b1118599.3545f8","name":"","path":"path","pathType":"msg","filter":"*.log","filterType":"str","dir":"files","dirType":"msg","x":480,"y":220,"wires":[["2c369e2e.840132"]]},{"id":"2c369e2e.840132","type":"change","z":"b1118599.3545f8","name":"copy files to payload","rules":[{"t":"set","p":"payload","pt":"msg","to":"files","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":220,"wires":[["12df3723.658b69"]]},{"id":"7266539f.9340cc","type":"function","z":"b1118599.3545f8","name":"make filename","func":"msg.file = msg.payload;\nmsg.filename = msg.path + \"\\\\\" + msg.payload;\nreturn msg;","outputs":1,"noerr":0,"x":140,"y":280,"wires":[["98a22fb9.cb5a"]]},{"id":"12df3723.658b69","type":"split","z":"b1118599.3545f8","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":890,"y":220,"wires":[["7266539f.9340cc"]]},{"id":"a25570de.29aed","type":"csv","z":"b1118599.3545f8","name":"Split Fields","sep":";","hdrin":"","hdrout":false,"multi":"one","ret":"\\n","temp":"Giorno, Ora, Stato, Programma, Lotto, Scheda","skip":"0","strings":false,"x":530,"y":280,"wires":[["71d7613e.abfca"]]},{"id":"5194020f.43fdfc","type":"MSSQL","z":"b1118599.3545f8","mssqlCN":"e91a56e2.a1e9f8","name":"DVC to SQL","query":"insert into Output_Produzione (\n Centro_di_Lavoro, \n data, \n n_ord_prod, \n n_operazione, \n articolo, \n VarINT1,\n VarCHAR1,\n Tempo)\nVALUES (\n  1109,\n  '{{{payload.DateTime}}}',\n  '{{{payload.LottoRight5}}}',\n  '{{{payload.LottoLeft4}}}',\n  '{{{payload.Programma}}}',\n  '{{{payload.Scheda}}}',\n  '{{{payload.Stato}}}',\n  '{{{payload.Tempo}}}')","outField":"payload","returnType":"0","throwErrors":"0","x":990,"y":280,"wires":[[]]},{"id":"71d7613e.abfca","type":"function","z":"b1118599.3545f8","name":"NEW transform DVC","func":"//copy of original payload for debug output\nmsg.origPayload = msg.payload;\n\n//make a copy of the row data... in some flows doesn't work ... WHY????\n//let row = {...msg.payload};\n\nif (msg.payload.Stato == \"START\"){\n    //Store Data and Lotto of the \"START\" Record to calculate delta time with the \"END\" record\n    global.set(publicVariables.Data_START, msg.payload.Ora);\n    global.set(publicVariables.Lotto_START, msg.payload.Lotto);\n    global.set(publicVariables.Scheda_START, msg.payload.Scheda);\n\n}\nelse {\n    \n//If any condition is false, the record is skipped\n    if (msg.payload.Stato == \"END\"){\n        //recall public variables\n        var publicVariables = global.get(\"publicVariables\");\n\n        //Check if START lotto end END Lotto are the same\n        if (msg.payload.Lotto == publicVariables.Lotto_START){\n            //calculate delta time using the global variable Data_START\n            var Calcola_Tempo = (msg.payload.Ora - publicVariables.Data_START);\n            //calculate Quantity  using the global variable Scheda_START\n            var Calcola_Qta = (msg.payload.Scheda - publicVariables.Scheda_START);\n\n            if (msg.payload.Lotto !== undefined){\n                var WO = msg.payload.Lotto.substr(5,6);\n                var OP = msg.payload.Lotto.substr(0,4);\n\n                if (msg.payload.Programma !== undefined){\n                    var Prog = 'AP11'+ msg.payload.Programma;\n    \n                    if (msg.payload.Scheda !== undefined){\n                        var Sch = msg.payload.Scheda;\n            \n                        //solo se tutti gli IF sono andati a buon fine\n                        //preparo il messaggio\n            \n                        var strG = msg.payload.Giorno;\n                        var strO = msg.payload.Ora;\n                        //split Data dd/mm/yyyy hh:mm:ss\n                        var D = strG.substr(6,4)+'/'+strG.substr(3,2)+'/'+strG.substr(0,2)+' '+strO;\n\n                        msg.payload = {\n                            a: 1109, //not sure what this is about?\n                            //DateTime: formatDT(row.Giorno, row.Ora), //Call a function to make the correct DATETIME string\n                            DateTime: D,\n                            //LottoRight5 : lottoParts[1],  //characters right of the '/' \n                            //LottoLeft4: lottoParts[0],  //characters left of the '/' \n                            LottoRight5 : WO,\n                            LottoLeft4 : OP,\n                            Stato: Status, //add Stato to the payload\n                            Programma: Prog, //add Programma to the payload\n                            Scheda: Sch, //add Scheda to the payload\n                            Tempo : Calcola_Tempo,\n                            Qta : Calcola_Qta\n                        }\n                    }\n        \n                }\n            }\n        }\n    }\n\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":760,"y":280,"wires":[["2915102.0f697f"]]},{"id":"b64b201.b7b0ae","type":"inject","z":"b1118599.3545f8","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":80,"y":140,"wires":[["69156b95.e64ca4"]]},{"id":"2915102.0f697f","type":"debug","z":"b1118599.3545f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":950,"y":340,"wires":[]},{"id":"69156b95.e64ca4","type":"function","z":"b1118599.3545f8","name":"Declare Global Variables","func":"var publicVariables = {\n    Data_START: \"00:00:00\",\n    Lotto_START: \"0\",\n    Scheda_START: \"0\"\n}\nglobal.set(\"publicVariables\", publicVariables);\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":140,"wires":[["ab3cd84c.703898"]]},{"id":"e91a56e2.a1e9f8","type":"MSSQL-CN","z":"","tdsVersion":"7_4","name":"Scambio_NAV","server":"srv-dc","port":"1433","encyption":true,"database":"Scambio_NAV","useUTC":true,"connectTimeout":"90000","requestTimeout":"90000","cancelTimeout":"90000","pool":"5","parseJSON":false}]
You haven't told us where the error is generated or what the error says.
Have a look at the node-red docs page Writing Functions which will show you how you can do simple debugging by inserting node.warn() at appropriate points in the function so you can work out what is going wrong.
