I am using the chart as the only item in the dashboard group so there is no need for a second title so I decide to leave the label blank. If I leave it blank, the space for the label takes up half of the space that is allocated to the chart item.
Is there a way to remove the space that is normally used for the label (not needed) and allow the chart to take up the given space?
Thanks for the display tip, It helps remove the white space, but doesn't make the problem go away of resizing the chart to take up that white space. (aka make the chart taller).
