Good day,
I have a function node that loops through an array and outputs 4 distinct messages via 4 different outputs. Each message has a unique indicator, i.e. 1m, 5m, 15m, 1hr.
Under certain circumstances, the node may output multiple msgs within a very short amount of time (less than a few seconds), because multiple criteria have been met.
I'd like to somehow wait after the first message is received, to see if other messages arrive, example:
1m is sent, wait to see if 5m, 15m, or 1 hr also arrive within a few seconds, if so, only send on the highest value, if not, return the original msg (in this case 1m).
How can I best achieve this?
Many thanks in advance.
P.S. My ideal scenario would be to state that criteria x and x and x was met, but I'm not sure if this is possible!
