I have the following package.json file
"name": "node-red-contrib-personal",
"version": "1.0.0",
"description": "Node-RED package developed by me",
"dependencies": {
"node-red": ">=2.2.0",
"node-red-dashboard": "3.1.7",
"node-red-contrib-iiot-opcua": "4.0.1",
"node-red-contrib-influxdb": "0.6.1",
"node-red-node-mysql": "1.0.1",
"node-red-node-rbe": "0.5.0",
"node-red-node-smooth": "0.1.2",
"node-red-contrib-modbus": "5.21.2",
"node-red-contrib-ui-led": "0.4.11",
"node-red-node-random": "0.4.0",
"node-red-node-email": "1.15.1",
"node-red-node-data-generator": "1.0.1",
"node-red-node-ui-table": "0.3.12"
"files": [
"examples"
"keywords": [
"node-red"
"scripts": {
"start": "node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS --userDir=/data"
my Dockerfile:
FROM nodered/node-red:2.2.2 as build
COPY package.json .
RUN npm install --unsafe-perm --no-update-notifier --no-audit --only=production
FROM build as prod
# Copy assets to `/data` directory
COPY ./data /data
CMD [ "npm", "start" ]
This builds the container will all the necessary dependencies but I am not sure where should I add my folder of examples to in the container?
My project structure is as follows:
├── Dockerfile
├── README.md
├── data
│ ├── flows.json
│ └── settings.js
├── examples
│ ├── Example1InfluxDB.json
│ ├── Example1MQTT.json
│ ├── Example1MySQL.json
│ ├── Example2Influxdb.json
│ ├── Example2MQTT.json
│ ├── Example2MySql.json
└── package.json
I have tried entering the docker container via:
docker exec -it custom-node-red-container /bin/bash
and tried searching for node-red-contrib-personal within the node_modules/ directory in the /usr/src/node-red working directory as well as under /data/node_modules/ directory
but neither the directory nor the examples are available.
Are there some steps that I might have missed here?
