Hi! I have a int value y msg, but now i need insert this value into a postgresql.
Postgresql query incorrect because cant read "msg":
INSERT INTO scada_level (datetimeLevel,level) VALUES (current_timestamp,msg);
How can i put msg value in query?
Thanks!
There’s a great page in the docs (Working with messages : Node-RED ) that will explain how to use the debug panel to find the right path to any data item.
Here:
I only need payload to insert in query.
How can i insert msg.payload into a query?
thanks!
Build the query using the msg parts you need, getting the path to the items of interest like @zenofmud showed you.
There are examples on the nodes readme page (assuming you are using node-red-contrib-postgresql - you didnt say!)
e.g...
SQL query template
This node uses the Mustache template system to generate queries based on the message:
-- INTEGER id column
SELECT * FROM table WHERE id = {{{ msg.id }}};
-- TEXT id column
SELECT * FROM table WHERE id = '{{{ msg.id }}}';
This works but is prone to SQL Injection and quote errors.
This is better...
Parameterized query (numeric)
Parameters for parameterized queries can be passed as a parameter array msg.params:
// In a function, provide parameters for the parameterized query
msg.params = [ msg.id ];
-- In this node, use a parameterized query
SELECT * FROM table WHERE id = $1;
Named parameterized query
As an alternative to numeric parameters, named parameters for parameterized queries can be passed as a parameter object msg.queryParameters:
// In a function, provide parameters for the named parameterized query
msg.queryParameters.id = msg.id;
-- In this node, use a named parameterized query
SELECT * FROM table WHERE id = $id;
Steve-Mcl:
Thnaks! Now is correct with msg.params = [ msg.payload ];
