How to pass msg value to switch topic field
Hi
I want to set Topic filed with special expression: {{{msg.prex}}}_test in the switch node, but it not work.
How can I fix it?
Thanks!!!
[{"id":"992e19b1.96722","type":"ui_switch","z":"7c707aa7.c06c4c","name":"loop","label":"loop","tooltip":"","group":"3fe9dd19.60393a","order":17,"width":3,"height":1,"passthru":true,"decouple":"false","topic":"{{{msg.prex}}}_test","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"x":490,"y":320,"wires":[["d02d8b77.f0b2f"]]},{"id":"8bfd9b7c.e99098","type":"inject","z":"7c707aa7.c06c4c","name":"","props":[{"p":"prex","v":"prex","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":320,"wires":[["992e19b1.96722"]]},{"id":"d02d8b77.f0b2f","type":"debug","z":"7c707aa7.c06c4c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"topic","targetType":"msg","statusVal":"","statusType":"auto","x":740,"y":320,"wires":[]},{"id":"3fe9dd19.60393a","type":"ui_group","name":"rule1","tab":"4679b587.ba0d2c","order":2,"disp":true,"width":7,"collapse":true},{"id":"4679b587.ba0d2c","type":"ui_tab","name":"场景一","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Hi, in order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
It doesnt work like that. Use JSONata or a template node or a function node instead
in a function...
msg.topic = msg.prex + "_test"
as JSONata
in a template
Demo flow...
[{"id":"92707120.1714","type":"change","z":"336fad55.d74c02","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"prex & \"_test\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":598,"y":416,"wires":[["1c5263f1.b1721c"]]},{"id":"c7fdea45.89c018","type":"template","z":"336fad55.d74c02","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{{prex}}}_test","output":"str","x":588,"y":464,"wires":[["6c7353f4.8f266c"]]},{"id":"5b5aa9d3.ba3608","type":"inject","z":"336fad55.d74c02","name":"msg.prex = \"hello\"","props":[{"p":"prex","v":"hello","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":378,"y":368,"wires":[["c7fdea45.89c018","92707120.1714","ef35e9ea.91a7b8"]]},{"id":"1c5263f1.b1721c","type":"debug","z":"336fad55.d74c02","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"topic","targetType":"msg","statusVal":"topic","statusType":"auto","x":748,"y":416,"wires":[]},{"id":"6c7353f4.8f266c","type":"debug","z":"336fad55.d74c02","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"topic","targetType":"msg","statusVal":"topic","statusType":"auto","x":750,"y":464,"wires":[]},{"id":"ef35e9ea.91a7b8","type":"function","z":"336fad55.d74c02","name":"","func":"msg.topic = msg.prex + \"_test\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":588,"y":368,"wires":[["30f0f154.562aee"]]},{"id":"30f0f154.562aee","type":"debug","z":"336fad55.d74c02","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"topic","targetType":"msg","statusVal":"topic","statusType":"auto","x":748,"y":368,"wires":[]}]
Thanks for your reply, I will try.
