I have a http-in node and a http-request node, between them is a function node to handle parameters which post to http-in node, but the http-request node cannot receive the right parameters. How can I fixed it.
the flow code is
"id": "efbbf209f839382a",
"type": "tab",
"label": "execute",
"disabled": false,
"info": "",
"env": []
"id": "dda525132ed420c7",
"type": "http in",
"z": "efbbf209f839382a",
"url": "/device/function/AJ",
"method": "post",
"upload": false,
"swaggerDoc": "",
"x": 230,
"y": 360,
"05f4c5a8ca1ab45a"
"id": "651e0e989fa4d9b5",
"type": "http request",
"name": "request a list",
"method": "POST",
"ret": "txt",
"paytoqs": "query",
"url": "http://10.51.9.130:30768/hjmos-device/point/queryVirtualPoint",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"x": 750,
"y": 360,
"6cd08b0d40cb3fc7",
"940ddf000262ad49",
"e8b5c3d557c5427a"
"id": "d77dd7344222f345",
"type": "switch",
"property": "payload.code",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "0",
"vt": "str"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 1090,
"y": 380,
"94ead5091659165e"
"bd188e226ec2f1ed"
"id": "bd10e0b7600a418d",
"type": "function",
"name": "set some flow vars",
"func": "flow.set(\"ID-Token\", msg.headers['id-token'])\nflow.set(\"Authorization\", msg.headers['authorization'])\n// flow.set(\"devId\", msg.payload.devId)\nreturn msg",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 760,
"y": 280,
"3d086c68e00395b4"
"id": "3d086c68e00395b4",
"type": "debug",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"statusType": "auto",
"x": 960,
"y": 280,
"id": "6cd08b0d40cb3fc7",
"type": "debug",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 1000,
"y": 480,
"id": "bd188e226ec2f1ed",
"type": "http response",
"statusCode": "",
"headers": {},
"x": 1290,
"y": 460,
"id": "94ead5091659165e",
"type": "function",
"name": "set params",
"func": "const status = msg.payload.data == 0 ? 0 : 1\n\nmsg.payload = {\n code: 0,\n\n data: {\n status\n }\n \n}\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1300,
"y": 380,
"e3d96df669171074"
"id": "940ddf000262ad49",
"type": "json",
"property": "payload",
"action": "",
"pretty": false,
"x": 930,
"y": 360,
"d77dd7344222f345"
"id": "8c2b31c72e0850c8",
"type": "inject",
"name": "测试",
"props": [
"p": "payload"
"p": "headers",
"v": "{\"id-token\":\"86ba0e17-2510-4f45-be5c-18abe63f86a4\",\"authorization\":\"Basic MTAxOjEyMzQ1Ng==\"}",
"vt": "json"
"p": "post",
"v": "Query_ComDetect_CCTV",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "{\"groupCode\":\"Query_Run_Status_AJ\",\"params\":{\"lineId\":6,\"stationId\":79,\"gate\":1}}",
"payloadType": "json",
"x": 470,
"y": 260,
"651e0e989fa4d9b5"
"id": "e8b5c3d557c5427a",
"type": "debug",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"complete": "req.body",
"x": 1040,
"y": 560,
"id": "664ea8e55a8894aa",
"type": "debug",
"active": true,
"tosidebar": true,
"console": true,
"tostatus": true,
"x": 740,
"y": 480,
"id": "e3d96df669171074",
"statusCode": "",
"headers": {},
"x": 1470,
"y": 380,
"id": "05f4c5a8ca1ab45a",
"type": "function",
"name": "设置传参",
"func": "msg.headers = msg.req.headers\n\nconst { lineId, stationId, devId } = msg.payload\n\nmsg.payload = {\n \"groupCode\": \"Query_Run_Status_AJ\",\n \"params\": {\n \"lineId\": lineId,\n \"stationId\": stationId,\n \"gate\": devId\n }\n}\n\nmsg.ip = global.get('ip')\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 480,
"y": 360,
"651e0e989fa4d9b5",
"bd10e0b7600a418d",
"664ea8e55a8894aa"
