Hello I am new with node red. Currently, I am working with node-red and mysql database for my final year project. I would like to send temperature data to the database but i have error stated that the array is undefined.
this is my node red flow..
and this is the function in mysql function
var test = msg.payload;
var temp = test.temperature;
msg.payload = [temp];
msg.topic = "INSERT INTO temperature(temperature) VALUES (?)";
however, the msg.payload :
INSERT INTO temperature(temperature) VALUES (?) : msg.payload : array[1]
[ undefined ]
can you help me to figure out my problem?
Hi, welcome to the forum.
Unless you name your debug nodes it is difficult to tell from a picture.
At a guess, msg.payload is a number BUT here...
you are affectively saying "Set msg.payload to a new array [ ] and put msg.payload.temperature inside"
Try this instead...
const temp = msg.payload;
msg.topic = "INSERT INTO temperature(`temperature`) VALUES (?)";
PS, please remember to wrap code in three backticks
like this
if i want to add another column such as id from the node red together with the temperature data .. how should i write it?
if the data comes from different nodes, then you need to join the 2 bits of data together into 1 message/payload so that you can use them together in your insert query.
See this article in the cookbook for an example of how to join messages into one object.
i have tried using join, but i still got an error
this is the debug message:
{"INSERT INTO temperature(temperature) VALUES (?)":[36.75],"INSERT INTO temperature(id) VALUES (?)":[{"id":1729336}]}
how ever, the id is not updated in mysql.
can you please help me.
dont put the object in the payload array - only put the value.
e.g.
msg.payload = [ msg.payload.id ];
or if you have 2 params then update your query and add the 2 params (use debug window as instructed below)
const data = msg.payload;
msg.payload = [data.id, data.temperature];
msg.topic = "INSERT INTO temperature(`id`, `temperature`) VALUES (?,?)";
↑ does that make sense?
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
