Mysql data logging
I have to log 5 data together in different column,
I write this query but it give "ER_PARSE_ERROR" please help.
var co = { payload: msg.payload[0]};
var ox = { payload: msg.payload[1]};
var lux = { payload: msg.payload[3]};
var temp = { payload: msg.payload[2]};
msg.topic = 'INSERT INTOnode-red.final(CO,OX,Lux,Temp) VALUES (' + co + ',' + ox + ',' + lux + ',' + temp + ')';
I get data in this form whic i have to log in to my sql.
array[5]
0: "4"
1: "000"
2: "000"
3: "0032"
4: "00"
If you are using node-red-node-mysql, have you looked at the documentation for that node?
If your payload is an array, then the first 4 lines should be
let co = msg.payload[0];
Same for ox, lux and temp
Also are these enter into Db as strings? If so they need to be quoted in the sql statement, or converted to numbers if numeric.
Thanks again E1cid.now its working.
