Dear All,
We are trying to insert some data to MySQL - Table but data not adding. Any issue with the following configuration since data logging is not happening. Table showing no records.
You have 6 question marks and only 5 values in the payload.
Also, you don't appear to have connected the function node output to a mySQL node.
First Column is Auto increment.
msg.topic = "insert into tblDB1_Test values (SLNo,?,?,?,?,?,Now(),'Admin')";
msg.payload = [
msg.payload.Word0,
msg.payload.Word2,
msg.payload.Word4,
msg.payload.Word6,
msg.payload.Word8,
Table Structure:
MariaDB [Plant]> desc tblDB1_Test;
| Field | Type | Null | Key | Default | Extra |
| SLNo | int(11) | NO | PRI | NULL | auto_increment |
| Word0 | decimal(10,9) | YES | | NULL | |
| Word2 | decimal(10,9) | YES | | NULL | |
| Word4 | decimal(10,9) | YES | | NULL | |
| Word6 | decimal(10,9) | YES | | NULL | |
| Word8 | decimal(10,9) | YES | | NULL | |
| LastUpdatedOn | datetime | YES | | NULL | |
| LastUpdatedBy | varchar(100) | YES | | NULL | |
8 rows in set (0.009 sec)
Try msg.topic = "insert into tblDB1_Test values (?,?,?,?,?,Now(),'Admin')
^ 5 question marks to match 5 items in payload
If that doesn't work, include the field names in the insert query.
msg.topic = "insert into tblDB1_Test (SLNo,Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy) values (SLNo,?,?,?,?,?,Now(),'Admin')";
msg.payload = [
msg.payload.Word0,
msg.payload.Word2,
msg.payload.Word4,
msg.payload.Word6,
msg.payload.Word8,
Error:
Error: ER_WARN_DATA_OUT_OF_RANGE: Out of range value for column 'Word0' at row 1
As i have said twice now, dont include the auto inc column.
msg.topic = "insert into tblDB1_Test (Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy) values (?,?,?,?,?,Now(),'Admin')";
msg.payload = [
msg.payload.Word0,
msg.payload.Word2,
msg.payload.Word4,
msg.payload.Word6,
msg.payload.Word8,
When you post an error like this - it is a good idea to include the data going in to the mySQL node so we can see what the value is & have an idea why it might be out of range.
Added but getting the following error. looks like Issue is not with Auto increment number but its related to PARSING.
error: Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '?,?,?,?,?,Now(),'Admin')' at line 1
i have another table which has auto increment column. While data inserting, we use SLNO and it is working fine. (Pls refer the below query)
var num = msg.payload
msg.topic = "insert into tblDB1_DBW12 values (SLNo,'DB1.WORD12',"+num+",Now(),'Admin')";
what mySQL node are you using? (share a link to it from the flows library )
I dont know about the others but node-red-node-mysql works with prepared statements syntax.
FYI: Building SQL dynamically like this ↑ opens you up to SQL injection
Another attempt...
msg.topic = "insert into tblDB1_Test (Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy) values (?,?,?,?,?,Now(),?)";
msg.payload = [
msg.payload.Word0,
msg.payload.Word2,
msg.payload.Word4,
msg.payload.Word6,
msg.payload.Word8,
'Admin'
I am using Node-Red-Node-Mysql node
Exporting the flow for your reference.
[{"id":"47169a4b.e85434","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"71460f4e.15746","type":"function","z":"47169a4b.e85434","name":"","func":"//var SLNo = 1;\n//msg.topic = \"insert into Test values (?,?,?,?,?,Now(),'Admin')\";\nmsg.topic = \"insert into Test (Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy) values (?,?,?,?,?,Now(),'Admin')\";\nmsg.payload = [\nmsg.payload.Word0,\nmsg.payload.Word2,\nmsg.payload.Word4,\nmsg.payload.Word6,\nmsg.payload.Word8,\n]\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":240,"y":60,"wires":[["43f32050.3b7a2"]]},{"id":"a5452b26.8604f8","type":"debug","z":"47169a4b.e85434","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":230,"y":120,"wires":[]},{"id":"3bff03e0.bc9c2c","type":"debug","z":"47169a4b.e85434","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":590,"y":60,"wires":[]},{"id":"71a905de.b51bdc","type":"s7 in","z":"47169a4b.e85434","endpoint":"d6429ddd.49b4f","mode":"all","variable":"","diff":true,"name":"PLC Data","x":80,"y":100,"wires":[["a5452b26.8604f8","71460f4e.15746"]]},{"id":"43f32050.3b7a2","type":"mysql","z":"47169a4b.e85434","mydb":"9721b43b.2be718","name":"","x":430,"y":60,"wires":[["3bff03e0.bc9c2c"]]},{"id":"d6429ddd.49b4f","type":"s7 endpoint","transport":"iso-on-tcp","address":"192.168.43.2","port":"102","rack":"0","slot":"1","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapter":"","busaddr":"2","cycletime":"1000","timeout":"2000","name":"s7 in","vartable":[{"addr":"DB1,WORD0","name":"Word0"},{"addr":"DB1,WORD2","name":"Word2"},{"addr":"DB1,WORD4","name":"Word4"},{"addr":"DB1,WORD6","name":"Word6"},{"addr":"DB1,WORD8","name":"Word8"}]},{"id":"9721b43b.2be718","type":"MySQLdatabase","name":"","host":"127.0.0.1","port":"3306","db":"Plant","tz":"","charset":"UTF8"}]
ADMIN Node. Wrapped your flow in a code block to fix forum formatting and permit it to be imported into node-red
sorry no Luck.
"Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '?,?,?,?,?,Now(),?)' at line 1"
Feed what is going into the sql node into a Debug node set to show Complete message and then show both what is going into the sql node and what is coming out.
well, I am at a loss. Perhaps you are using an old version?
You can drop back to unsafe dynamic SQL
var data = msg.payload;
msg.topic = `insert into tblDB1_Test (Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy)
values (${data.Word0},${data.Word2},${data.Word4},${data.Word6},${data.Word8},Now(),'Admin')`;
node.warn(msg.topic); //for debugging - remove me when working!
msg.payload = null;
i am using latest version of MySQL.
MariaDB [(none)]> SELECT VERSION();
| VERSION() |
| 10.3.27-MariaDB-0+deb10u1 |
Following are the result.
WARN:
//msg.topic = "insert into tblDB1_Test (Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy) values ({data.Word0},{data.Word2},{data.Word4},{data.Word6},${data.Word8},Now(),'Admin')";
ERROR:
Error: ER_PARSE_ERROR: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '{data.Word0},{data.Word2},{data.Word4},{data.Word6},{data.Word8},Now(),'A...' at line 1
you did something wrong. that should get changed to ...
values (1,2,3,4,5,Now(),'Admin');
what nodejs version are you using?
i tried using both.
msg.topic = "insert into tblDB1_Test (SLNo,Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy) values (SLNo,{data.Word0},{data.Word2},{data.Word4},{data.Word6},${data.Word8},Now(),'Admin')";
Results are as follows.
WARN:
Thats not what I told you to do. you have changed the ` backticks to double quotes.
i said...
msg.payload = null;
NOT msg.topic = "insert into tblDB1_Test
See the difference?
I used msg.topic = `insert into tblDB1_Test
even i tried with this...
Well it works for me. It is a valid SQL statement
I did this...
create database Plant;
use Plant;
CREATE TABLE tblDB1_Test (
SLNo int NOT NULL AUTO_INCREMENT,
Word0 decimal(10,9),
Word2 decimal(10,9),
Word4 decimal(10,9),
Word6 decimal(10,9),
Word8 decimal(10,9),
LastUpdatedOn datetime,
LastUpdatedBy varchar(100),
PRIMARY KEY (SLNo)
then used this...
[{"id":"cf9f8329.ccd46","type":"function","z":"47169a4b.e85434","name":"","func":"\nvar data = msg.payload;\nmsg.topic = `insert into tblDB1_Test (Word0,Word2,Word4,Word6,Word8,LastUpdatedOn,LastUpdatedBy) \n values (${data.Word0},${data.Word2},${data.Word4},${data.Word6},${data.Word8},Now(),'Admin')`;\nnode.warn(msg.topic);\nmsg.payload = null;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":652,"y":160,"wires":[["f2946f08.114f7","7324a8c6.66c808"]]},{"id":"3c4a55e4.1e54aa","type":"inject","z":"47169a4b.e85434","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"Word0\":1,\"Word2\":2,\"Word4\":3,\"Word6\":4,\"Word8\":5}","payloadType":"json","x":482,"y":160,"wires":[["cf9f8329.ccd46"]]},{"id":"7324a8c6.66c808","type":"mysql","z":"47169a4b.e85434","mydb":"9721b43b.2be718","name":"","x":818,"y":160,"wires":[[]]},{"id":"f2946f08.114f7","type":"debug","z":"47169a4b.e85434","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":658,"y":208,"wires":[]},{"id":"9721b43b.2be718","type":"MySQLdatabase","name":"","host":"127.0.0.1","port":"3306","db":"Plant","tz":"","charset":"UTF8"}]
Will try this. Tried most of the stuff...
meanwhile can you please share the flow.
